problem synthesizing for loop
zubairbasha
Newbie level 1
i am using CADENCE TOOlS
nclaunch for verilog(rlt) code
rc-compailer for synthesis
in one of my code i am using for loop... shown below
for(ST =1'b0;bk1>8'b0;ST =1'b0 )
begin
bk1 = bk1>>1;
if(bk1[0]==1) ST_ODD = ST_ODD+1;
else ST_ODD = ST_ODD;
end
next_state = s2;
in rc complier the following ERROR is generated...........
Elaborating top-level block 'encoding_technique1' from file '/root/rclabs/work/../rtl_mini_project/mini_project.v'.
Error : Reached maximum loop limit while unrolling loop. [CDFG-457] [elaborate]
: Loop maximum = 1024 in file '/root/rclabs/work/../rtl_mini_project/mini_project.v' on line 82.
Info : Deleting HDL design. [CDFG-305]
: Design 'encoding_technique1'.
Module 'encoding_technique1' contains errors and cannot be elaborated.
i gave following command in my sdc file
set_attribute hdl_max_loop_limit 5000
still i failed to elaborate my code
what i understood is though my iterations are at mamxium 512 which is with in max limit of 1024 still i am unable to synthesis my code
can any one make me understand the mistake i am doing here.
Thanks in advance:)
You need to read up on the Verilog for loop. It's not a SW construct where you can modify the loop variable on the fly while running the code in a simulator. It's meant for producing parallel hardware.
