Generating sine wave for testbench in systemVerilog
drk15
Newbie level 3
Hello All,
I am trying to generate a sine wave with frequency 5GHz with 0.5V offset and 0.3V amplitude. This is what I do.
// Testbench
`timescale 1ps/10fs
import "DPI" pure function real sin (input real rTheta);
module testbench;
// Declarations
parameter sampling_time =1;
const real pi = 3.1416;
bit sampling_clock=0;
real freq = 5e9;
real offset = 0.5;
real ampl = 0.3;
real sine_out;
initial begin
$fsdbDumpvars(0,"testbench" , "+all");
$timeformat(-12,3,"ps",1);
#1000 $finish;
end
always sampling_clock = #(sampling_time) ~sampling_clock;
always @(sampling_clock) begin
sine_out = offset + (ampl * sin(2*pi*freq*$time));
$write("Sine value at time=%0g is =%0g\n",$time,sine_out);
end
endmodule
After doing this, I check the generated waveform in nWave, but I think the generated wave is not 5G frequency but a lot more. I do not understand what is wrong.
ANy help will be appreciated.
Thanks.
I think the difference you would be seeing is because of mismatch between units of frequency and time. Time is in pico second whereas frequency is in per second (1 Hz = 1 per second).
Hey,
Thanks a lot FreeMAn0110 for your reply.
You are right, the problem was about the time units.
I just replaced sine_out = offset + (ampl * sin(2*pi*freq*$time)) with sine_out = offset + (ampl * sin(2*pi*freq*$time*1e-12)) and its working now.
Thanks a lot. :)
