d123
Advanced Member level 5
Let me break this to you (not especially) gently, John. You can't use a monostable timer to drive a speaker because a speaker is an oscillatory device, it has a (paper) membrane that needs to oscillate to make any sound - otherwise it will just make a pathetic, barely audible crackle. The YouTube video you posted is no use to your objective, unfortunately, unless you use a DC buzzer and that will limit the sound you can reproduce to the default buzzer sound. That removes the need to answer the first question. The second question is (with an astable 555 circuit): use a smaller capacitor around the speaker and a smaller capacitor from pins 2 and 6 on the astable timer (the one to the right).
I fail to understand why a person who makes a seven-segment display circuit function - who says they had no prior electronics experience - thinks they are unable to make a simple 555/556 circuit, it seems more like stubborn caprice than truthfulness. I remember the start of this thread and you fussed over suggestions and pretty much went back to the first one suggested to you, here we go again.
Lastly - I just wanted to help you, so don't bother with the "helped me" button, it's not about "points mean prizes" for me - I'll guess that in this film you're the star of here on the forum you haven't been able to notice that people on this forum show their gratitude to the people who help them by pressing the "helped me" button, give it a try sometime and be a little less selfish/self-centred.
Sorry to be honest with you, it's not very glamour and showbiz but it is all fair comment by now...
Anyway, you need an astable timer and you're more than capable of putting that 556 circuit, or two 555s, together by yourself.
Good luck and hope it all works well for you. Thanks again!
See you!
I appreciate the effort here, gents. Thank you. But, I'm going with the YouTube video I posted last night--it's just easier for me. Even with your video, I don't know how to even start this circuit.
A couple of questions:
How can I add the 12 toggles to the YouTube circuit?
What would I need to adjust pitch and duration? Just different values of capacitors and resistors? I need a higher pitched tone and shorter duration than what was in your video, D123.
Thanks again!
John
See you!
