VERY GOOD COLLECTION OF HFSS 10 PROJECTS
Re: hfss yagi examples
does anyone have a patch example for download?
Check out this one:
  • HFSS_Tutorial good.pdf
Reactions: prilla
    prilla
hi all,
i am working on a rectangular spiral microstrip antenna. i am using coaxial feed, but the problem is, i am getting radiation in exactly opposite direction. i working with HFSS 10. Please help.
can you post a picture if your hfss design? because i think your feeding technique is wrong. and did you try applying a ground plane in your whole antenna, this would reflect the whole radiation in the direction opposite to it.
For this, insert a surface and just declare it infinite ground plane from the boundaries.
this is how it looks, i have applied ground but finite one. infinite ground is impractical. i have to fabricate this antenna.
also this is the radiation pattern of above design..
and yes i did get radiation pattern above patch when i inserted infinite ground.
can you help me to get correct pattern without infinite ground?
Any Help on this.. ? am a Total Newbie about all this..
"Dual Band-Reject UWB Antenna With Sharp Rejection of Narrow and Closely-Spaced Bands"
plz i want a butler matrix design with HFSS
