VERY GOOD COLLECTION OF HFSS 10 PROJECTS
hello all!!
i am working on RF MEMS in Comsol to remove stiction problem between surfaces. But iam not getting the desired results. Actually, i have to submit my proj now, can any one please upload the complete report and either ADS,HFSS or comsol design....
I will sharing my COMSOL design after i complete it.
Thankyou
plz mail at
rag_una@yahoo.com
Do anyone have source for Circular patch antenna at 1ghz
Im using ansoft
Thanks
i need a microstrip to waveguide transition, someone help to me??
Hi, Salva,
I used a sandiwitch structure for microstrip to WG transition. The upper and the lower is Altimum, and the middle is microstrip. The upper is about lamda/4 resonator at WG port, the lower is through WG, and the middle has a microstrip probe. From 50R microstrip line, maybe use 2 or 3 lamda/4 impedance transition, and the end of probe is larger than the 50R line width. All the variable you can set in HFSS, and optimum for the desired freq band.
I do it successfully up to 40G. And I saw someone use it more than 100G. Good luck.
i need for 80 to 110 ghz, but the results doesn't like to me
can you do a hffs structure?
i think that my problem is the air boundary radiaton to catch the microstrip, because waveguide has a perfect e boundary.
my english is very bad, sorry xd
pag 2, fig number 2
waveguide 10
microstrip adaption 50 ohms
  • 01098023.pdf
Here is one paper from 80G~120G.
But I use sandiwitch structure, that is easy to assembly. But I never try to use it to 100G. You can try and tell us result.
  • 07810@52RD_Full_band_waveguide-to-microstrip_probe_transitions[1].pdf
  • 07810@52RD_A_novel_coaxial_probe_waveguide_to_microstrip_transition[1].pdf
Reactions: prilla
    prilla
i have problems with the boundaries and i don't know how to solve it.
i used fig2 of this pdf: 07810@52RD_Full_band_waveguide-to-microstrip_probe_transitions[1].pdf
i upload a .rar, there are a file of transition, can you help me please?
i have problems tu upload hfss file:
The following errors occurred:
Microstrip_i_guiacopia.hfss: Invalid File
  • Microstrip_i_guiacopia.rar
hey!
somebody knows how to pass an hfss archive to a protel?
thanks
Re: monopole hfss
hi,
I am designing a ML to SL transistion ,in that i have made the layout using autocad .after assinging the material property and all.It shows via and substrate are intersect .
I want to remove the intersect option to continue the simualtion .
Can you let me know the option to do in HFSS.
You can also reply to me personal id also .
viswaimpulse@gmail.com
Thanks
Re: monopole hfss
thank u... very much... can u pls help me in designing of broadband planar monopole elliptical antenna.... pls help me out... i ll be very greatful to u...
many request various antenna designs for HFSS, I think the best way is to use the HFSS ANTENNA DESIGN KIT available for free at **broken link removed**
the kit gets design parameters for different types of antennas and gives a complete simulation project, including the somehow hard to achieve radiation patterns by defining the correct air boxes and ports.
thanks for your share !!
hi all,
do u have any balanced Unbalanced transformer design(BALUN) on RFIC CMOS technology.
