4C
Newbie level 3
- Joined
- Dec 2, 2005
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,342
usb blaster
Hi all,
I don't have access to a USB Blaster to be able to have a go at reverse engineering it, but I have found bits and pieces that may be useful to someone!
At:-
Contains the file 'Rev_B.epp', it looks like the contents of the EEPROM attached to the FTDI chip, to get the correct VID/PID, etc.
http://www.mesanet.com/software/parallel/jtag.zip
Has some HDL for a USB JTAG programmer for Xilinx, but makes interesting reading. They use commands to setup a byte count and address, then stream the data across.
The 64 possible NOP's in khach's email could indicate a 64 byte max transfer size, and is used to get back to the command state????
Maybe the USB Blaster uses a similar system, it would make sense to use this method as it makes better use of the USB bandwidth, rather that sending entire bytes just to toggle 1 bit.
I also found a Russian site with some info :-
http://njnmnp.narod.ru/usbblaster/usbblaster.html
But I couldn't download some of the files.
And the Russian to English translator I tried did not make much sense?
BR,
4C.
Hi all,
At:-
BR,
4C.
