adewaledipo
Junior Member level 1
- Joined
- Aug 31, 2007
- Messages
- 15
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,354
@DeepOne, can you help me get the chip and the programmer so that i can do the stuff myself
this code wizard generated code is useless in that case and it is necessary to change it with code from .c file.you have already generated the code using code wizard
registers description possible to find in datasheet, simple designs from C language - in any book about this. Or ask more exactly.comment the code
no, this is usual steel core based converter. Particularity in mega8 deadtime generation. Because mcu timer1 has only two outputs also used external commutation with additionally mcu pins.Is this a single stage High frequency ferrite core based converter.
