T
treez
Do you agree that regarding the choice between LLC converter and Phase Shift Full Bridge (PSFB) converter, you would virtually always choose the LLC converter? You would only choose the PSFB if either input or output voltage were highly variable.
The reason the LLC is always preferred over the PSFB is because the LLC has far less modes of operation where destructive latch-up of the FETs can take place due to reverse recovery of the primary side FET’s intrinsic diodes. Do you agree?
After all, in an LLC , the mentioned reverse recovery problem only happens during startup, but can be avoided by a good soft start. So, LLC always better than PSFB(?)
The below articles (1 to 3) tell of the reverse recovery problem in the PSFB…..it cannot be avoided with the PSFB, so you just have to use special FETs with ultra low Qrr and hope you don’t fall victim to the problem.
1…“MOSFET body diode recovery mechanism in a phase-shifted ZVS full bridge DC/DC converter”
https://www.st.com/st-web-ui/static...ical/document/application_note/CD00171347.pdf
2…“FCS Fast Body Diode MOSFET for Phase-Shifted ZVS PWM Full Bridge DC/DC Converter”
https://www.fairchildsemi.com/application-notes/AN/AN-7536.pdf
3…Design of Phase Shifted Full-Bridge Converter with Current Doubler Rectifier
file:///C:/Users/andrew/Downloads/ZVS_Full-Bridge.pdf
Top of page 7 of the following shows how there are far less failure modes of the primary side FETs in an LLC converter than in a Phase shift full bridge converter.
“Primary Side MO S F E T Selection for LLC Topology”
https://www.infineon.com/dgdl/Infin...y.pdf?fileId=5546d46147a9c2e40147d3430e927e5d
Top of page 7:-
“”Design considerations of the power MOSFET in the primary side LLC resonant converter are relatively simple compared to a phase-shifted full-bridge converter, as it is not affected by leading or lagging waveforms with regards to the power MOSFET. With the exception of the capacitive load resulting from overload or short-circuit conditions, during startup only system reliability issue caused by incomplete body diode reverse recovery of the power MOSFET need to be considered””
…so the LLC converter only has to be protected from primary FET failure during startup, whereas the Phase shift full bridge converter has more modes of operation where it may undergo catastrophic destruction of its primary side fets due to reverse recovery/latch-up.
Top of page 7:-
