The 6V zener diode supplies the Cmos 555 that draws a VERY low current and the third transistor. The other two transistors are not powered from the 6V zener diode, instead they are powered from 12V.Why only use the current from just the third transistor? Why are the others not included in that calculation?
The datasheet for almost every little transistor shows that it saturates (turns on like a switch) best when its base current is 1/10th its collector current.
You have six LEDs at 20mA each so their total is 120mA and the base current should be 12mA.
The datasheet for a Cmos 555 shows that with a 12mA load and a 6V supply, its output low voltage is about 0.5V and the base-emitter voltage of the PNP transistor (I looked at the datasheet of a 2N4403 ) is about 0.9V when it is saturated with a 120mA load. So the series base resistor has 12mA and a voltage of (6V - 0.5V - 0.9V=) 4.6v. Ohm's Law calculates the resistor value to be 4.6V/12mA= 383 ohms which is not a standard value so use 390 ohms.
No.So I use one power supply that powers both the chip and lights. The power going into the chip is limited by a resistor leading into the zener diode.
The transistors do not care about LEDs, instead they care about current. The datasheet for almost EVERY transistor shows that it saturates well (turns on) when its base current is 1/10th the collector current.I had planned on using 10 sets of 5 LED's (50 total) in series. Will the chip you mentioned handle the output to the transistors since I have drastically increased the current needed? Are the calculations you made for the resistor into the transistor the same for the other three into the other two transistors?
