I repeat: The NPN in the original circuit prevents the PNP from turning off because the emitter voltage of the NPN does not go high enough. Without the NPN then the Cmos 555 can turn off the PNP. I showed this in my first post.I will try to get a better picture of it but in my first post I have that same type of circuit drawn. The output was going to two transistors, a npn connected to a pnp. Output goes high and allows power to flow through the npn to turn off power to the pnp. Timing interval ends, npn goes off, pnp lets power flow through it. The capacitor could be connected to the LED's to ground. Would that discharge the capacitor? My original problem was the transistors had resistors running to them and I didn't know what they were for.
