No because there is a series current-limiting resistor from the output of the 555 to the base of the PNP transistor.If I am connecting a capacitor from either the collector or emitter to base, do I need to worry about any kind of reverse voltage or current going into the chip via the output pin?
The datasheet for almost every little transistor shows that it saturates (turns on like a switch) best when its base current is 1/10th its collector current.I couldn't remember if you or someone else mentioned it before but how do I determine the value of that resistor?
If the capacitor is connected to the output of the 555 then it will short circuit its output every time it switches then it is not a filter.Does the capacitor that is wired from the collector or emitter side to base need to come before or after the resistor on the base?
You DO NOT HAVE a 555. Instead you have a Cmos TLC555 which is very different.On a slightly separate issue, do you know how much voltage a typical 555 can take? I was thinking about running more of my LEDs in series so I wouldn't take up a lot of space for batteries, but it would mean a lot of voltage, about 17.5.
The base resistor connects between the output of the 555 and the base of the PNP transistor. You do not want to short circuit the output of the 555 to the collector of the transistor each time it switches, instead you want a filter so connect the capacitor directly to the collector and base of the transistor.OK, after reading your edit, if I connect the capacitor between the collector and base, does it matter if its before or after the resistor connected to the transistor?
The datasheets show the differences:What is the difference the difference between the CMOS and an ordinary 555? How would I go about selecting the correct chip to do what I want?
No, a voltage divider will not work because the base of the PNP transistor must be close to the positive supply voltage for it to turn off.If the voltage I need for the lights is too high for the CMOS, could I create a voltage divider somewhere in the circuit to limit it?
No. Your first post showed an NPN emitter-follower, not an NPN switch. Then the PNP transistor NEVER turns off.Wasn't that what I had drawn in my very first post?
It inverts the output of the 555 like this:Would the third transistor be another PNP and where would it go?
The zener diode has a rated operating current. Since the supply current for the Cmos 555 is very low and the third transistor uses only a few mA then use a zener diode rated at 5mA and calculate the value of the resistor feeding it by using 3mA for the third transistor and 5mA for the zener so the current in the resistor is 8mA. The voltage across this resistor is 12V - 6V= 6V so Ohm's Law calculates its value to be 6V/8mA= 750 ohms. You can use 680 ohms if 750 is not available.Do I calculate the resistor leading into the zener just like the ones for my LED's by using the voltage drop and the max current the chip I select can handle?
