KlausST
Advanced Member level 7
- Joined
- Apr 17, 2014
- Messages
- 26,355
- Helped
- 4,926
- Reputation
- 9,875
- Reaction score
- 5,803
- Trophy points
- 1,393
- Activity points
- 177,454
to get the information about the complex impedance of the load you need to simultaneously sample "voltage" and "current".
How many samples: Nyquist says at least twice the signal frequency. I recommend at least 4 samples per period. With 10MHz this means 40 Msamples/second. (are you able to do this?)
As i wrote before a lock in amplifier is far more simple. I used simple analog switches. then some Rs and Cs as low pass filters. The ADC can be very slow, because it simply has do measure about DC.
Anyway 10MHz is not that simple. Not with high speed ADC, nor with lock in amplifier. Expect a lot of error. In either case it needs a lot of experience to find the errors and cancel/calibrate them.
Klaus
Klaus
