naseerak
Full Member level 5
Thanks but what gauge, Length,Type and what volt will it produce at maximum load. You also mentioned in this thread earlier that in over load condition the DC Bus voltage significantly reduces and by this I guessed that You r using that Drop in Total DC Bus as over load condition But Later discarded that idea as the DC bus will also reduces when the battery discharges so no point in using that scheme. Should the shunt be of constant value as in the production stages this has to be taken in to account. currently I am planning to do it with Atmega8 as the prices has came down after a surge in prices a couple of year ago. Tahmid! What you prefer for such type of inverter the PIC or the Atmel. I am comfortable with the Atmel. If possible please Show your source code/Hex file for the benefit of all of us.
