Assuring stability with Voltage Mode TOPswitch Flybacks?
cupoftea
Advanced Member level 6
We are trying to use TOPswitch HX and JX flyback control chips , but with transformers with NP/NS's
which mean that our design is not supported by their PI Expert Suite software.
Please help us to use TOPswitch's in such use case?
As such, we need to be able to calculate the gain and phase margin of our TOPswitch designs. However, we cannot do
this since TOPswitch modulator gains are the secret IP of Power Integrations.
And since the PI Expert Suite software cannot be used with our transformer's, we cannot assure stability
of our designs. This is bad because voltage mode converters offer additional problems with stability and so
must be done with a feedback loop calculation.
The TOPswitch is a voltage mode controlled chip (certainly when on or near max power).
Transient response testing is not sufficient to prove good stability margins with
voltage mode converters like TOPswitch….as the following article by Dr Ray Ridley discusses...
Transient response & Loop gains of power supplies (Dr Ray Ridley)
..with a current mode SMPS, you can get better gain and phase margins by simply lowering the loop
bandwidth.....but this is not so for voltage mode converters. As the above discusses.
So we then need to calculate the gain and phase margins. -But this isn't possible with TOPswitch, since
the modulator gains inside the TOPswitch are kept secret.
So in summary, for a voltage mode converter, one must calculate out the gain and phase margins....ie, you have to make out
the Bode Plots.....you dont necessarily have to do this with current mode converters......Dr Mike Engelhardt emphasis this in 1:55 to 2:30
of his video as follows...
...But how do we calc the Bode plots for a TOPswitch when Power integrations keeps the internal modulator gain a secret?
The modulator gain is needed to be known to calc out the Bode plot.
In the following communication, Power Integrations applications engineers actually state that the
feedback loop parameters of the TOPswitch internals are the secret IP of Power
Integrations and so are not divulged to the public. Therefore, without the modulator gain of the TOPswitch
we are simply unable to do the feedback loop calculation for the TOPswitch..
Page 47 of "power supply design, volume 1:control" by Dr Ridley states that for a voltage mode flyback.."The crossover frequency should be at least twice the resonant frequency".......by "resonant frequency" , Dr Ridley means resonance of Cout and L(sec). [or rather "LE", the effective secondary inductance since its flyback and not full or half bridge).
Also, Basso states that Voltage Mode Flyback crossover should be three times less than the RHPZ frequency (our designs go into
CCM at low mains and so RHPZ becomes an issue)
….the above two facts mean that there is only a narrow band of possibilities for the crossover frequency of a voltage mode flyback like TOpswitch. A little variance in the tolerance of the opto, or whatever, and the whole thing could go unstable. Not only that,
but TOPswitch designs often use a NPN in the feedback loop. NPN's have very poor tolerance, and so the chances of running into
stability at some point with a TOPswitch design is quite high.
Page 25 of AN-47 shows the NPN being used in the topswitch feedback loop....
AN-47
Incidentally AN57 does not refer to TOPswitch HX or JX as the following tells....
Page 4 of AN57 by power integrations suggests that the LC resonant frequency of a TOPswitch flyback
should be greater than 500Hz...
AN57
This imposes a tight limit on the TOPswitch output capacitance, and throws into peril any output loading which may also feature an extra , large
electrolytic capacitor....instability may well then ensue.
Do you know what lies behind this recommendation of LC resonant frequency >500Hz?
Is it the fact that with TL431 based compensators that feature the "fast-lane/slow-lane" paths, the Type 3 compensator
is especially poor when LC resonance is >500Hz?
Here's a bit more on the TOPswitch Flyback output LC resonance frequency being >500Hz...
I mean, supposing your TOPswitch flyback suffers high variance in the opto CTR because you have five different parts as being "OK" in the BOM and need that flexibility to keep costs and lead times down....Or suppose the ESR (or the capacitance itself) of your output caps is highly variable.....or supposing some customers connect loads which comprise additional electro caps, thus dramatically increasing the output capacitance...etc etc.......current mode controllers can shrug this off and stay stable...a voltage mode converter may well go totally unstable under such changeable conditions.....
Like was sais, if the TOPswitch design is from the PIXIS design suite, or from the PI Expert software, then your good.....but if not......then surely one is in danger of instability?
I am not that surprised by the above, except that:
Power Integrations engineers also declare it as Voltage mode control.
is obviously a reference to closing the volt loop using the comp pin - nowhere do they say it is solely volt mode - which if some of the commenters on here had ever tried to build a CCM flyback under volt mode only - would realise their folly very quickly into the process - esp at light loads.
This is also why the ToP switch is limited in the lowest pri inductance it can switch, due to the leading edge blanking and steepness of current rise - factors that do not occur in pure volt mode.
also, nowhere does it state this: " Voltage Mode control when in "full frequency PWM mode" " they actually say pwm - which hides the operation nicely
the internal current mode loop exists nicely inside the ToP switch - with no fiddling needed by newbies - they have largely taken care of the volt loop with their current method and large cap on the comp pin - meaning anyone can close the loop and at worst case get a slow response - and at best case get a loop fast enough that only an internal peak current mode system can actually supply. QED.
Thanks, The PI engineers on their PI forum say its voltage mode when peak current is above 55% of imax.
Also i think we are talking at cross purposes again, because yes, it is not in Voltage Mode control at light load. (ie, when ipeak is at or less than 55% of imax)
The datasheet description nowhere depicts a peak current being taken to a PWM comparator along with the error amplifier signal.
The entire chapter 8 of Dr Basso's book is referring to it as Voltage Mode Control.....are you saying that Basso's entire 8th chapter of this book is wrong?
Dr Basso must have had permission from Power Integrations to write that. Dr Basso is one of the foremost SMPS control engineers in the world today.
According to you his entire 8th chapter is full of serious errors. ie mistaking Current Mode control for Voltage Mode Control.
Also, if its current mode then one would need to know the current sense resistors value , as its a needed feedback loop parameter.
I suspect that anybody can say anything no matter how outrageous about TOPswitch now and get away with it, because the Innoswitch appears to be the all encompassing part of Power Integrations now....at least regarding offline flybacks. Many TOPswitchs are now obselete or "not recomended for new designs".
Thanks but its only in voltage mode when ipeak is >55% of imax.
Ha ha, I got an advance draft of that book from M. Basso to check - but I was overseas and failed to do any reading before it was handed to the publishers
There is no where that PI explicitly states that it is in volt loop only above 55% of I max - reading comprehension again.
Also - you can use the ToPswitch as a UPF boost switcher - this would not be possible at all without current mode throughout - with a slow closing volt loop for the 385-420 VDC out.
and further please note:
you would never get close to 1kHz loop closure freq ( never mind 3kHz ) without an internal current loop - but only a learned mind would appreciate this fact. You'd be lucky to get 100Hz and be stable at no load.
QED.
Thanks but There is nowhere that it says its in Current mode when above 55% of imax either.
Its obvious from the explanation on page 9 of TOP-HX datasheet that its volt mode above 55% of imax.
Thanks but Voltage Mode is common in PFC boost controllers...take the LT1248 where you clearly see the artifical ramp into the PWM comparator...on page 11 block diag....
LT1248
Also, i suspect the equation 8.35 (attached) which depicts a type 3 transfer function for the TOPswitch/TL431/Opto configuration. The numerator shows "1+wz2/s", but a zero is of the form "1+s/wz2".
aaah, geez, the LT1248 uses ave current mode - where the slope comp is effectively built in to the Cea - otherwise it wouldn't work - at all.
it looks at the current and the rectified Vac in:
it's a copy of the UC3854.
It's a pity Basso didn't ask PI for full detail - closing a fast volt loop requires a fast internal current loop - else it don't work
the proof as always is in the pudding - try closing a volt only loop at 1kHz on LTspice, just in CCM at full power - you'll see . . . oh yeah - then do a load step from 60 - 100 % and back and see where your volt loop only gets you . . .
from your page 9, what is described is a round about way of describing peak current mode - which you are apparently unable to spot,
Thanks, but lets look at the Hiper-TFS, a 2 Tran Forward chip by Power Integrations.
Its feedback is analogous to that of the TOPswitch...except for Hiper-TFS it looks at the current being drawn out of the FB pin by the opto...and then assigns a duty cycle depending on that......whereas TOPswitch it looks at the 'excess' current being supplied into the CONTROL pin by the opto.
Hiper-TFS is definitely voltage mode......and so too is TOPswitch.
The basics of the operation of the Hiper-TFS are essentially the same as the TOPswitch with regard to duty cycle setting, and both are in Voltage Mode Control when at Max Power.
I am pretty sure Power Integrations dont do any Frequency compensated chips which are current mode control when at max power. (dont know about innoswitch as it doesnt say, and the user doesnt do any frequency compensation for that anyway).
how unlikely is it that PI would drop out of pk current mode at near full power - very unlikely - the gain change and the double pole would quickly lead to oscillation for solely volt mode
Thanks, but Hiper-TFS is voltage mode...and they just get people to compensate it for voltage mode...ditto the TOPswitch.
Thanks, but what about Hiper-TFS? , which they state is Voltage Mode Controlled. Are you saying that doesnt work too?
I appreciate the Hiper-TFS has no RHPZ, but with TOPswitch flybacks, they are arranged so that the RHPZ is pushed out to high frequency.
Thanks, i appreciate its called "average current mode"...but its a Current Error amplifier output feeding into a PWM comparator, along with an artifical ramp, and is effectively Voltage Mode Control as such....as you know, it does not "look" at the instantaneous peak current as in Current Mode Control. The LT1248 is effectively "voltage mode control applied to the current error amplifier output instead of to the voltage error amplifier output."
--- Updated ---
___________________________________________----
Well, If the TOPswitch is not in Voltage Mode then its very strange, because
the Bode Plot calculations which consider it as voltage mode, come out very identical to the
actual Bode plots given in the DER243 application note. (and the ones in DER243 are from
the lab with use of a gain phase analyser.)
(excel as attached)
However, I had to use Basso's equation for the TOPswitch/TL431/Opto transfer function.
(on page 467 of his book "Designing control loops......")
Also, I had to use Basso's Voltage Mode CCM Power stage transfer function as in page 231 of his book "SMPS".
But I had to switch the gain factor from that shown in the "SMPS" book to the one given in AN57 equation 11.
This had to be done as Power Integrations don't give the ramp peak voltage for TOPswitch.
(However, if i had taken the ramp peak as 1Volt, then i could have just used Basso's equation 2A-18 in its whole-some form
as that would have been the same as the AN57 supplied gain.)
So if TOPswitch is not in voltage mode, then how has the attached come out as very identical to the
DER243 supplied Bode Plots.?
DER243
  • Loop Bodes _DER243 65W Flyback TOPswitch_Basso.zip
No it ain't - and it does not say so in plain english anywhere I can see.
closing the external volt loop - yes - easy & pleasant, knowing the high performance requires an inner current loop - priceless,
again, why would PI go to all the trouble of using the internal fet to provide a temperature compensated I sig - and then not use it for best performance ?
again, all the proof needed is to try closing a loop at 1kHz in LT spice for an 100 watt flyback - that is just in CCM at full power - and load stepping - using volt mode only - suddenly you're down to sub 100Hz and a type 4 compensator to have stability at light loads.
QED.
This is not obvious at all.
Neither does it ever mention current mode.
Your case seems to be based not on any information from power integrations, but rather your own intuition as an engineer. Understandable, often we have to fill in the gaps with our best judgement.
My own intuition doesn't see any issue with voltage-mode control so long as one is willing to accept a very low crossover frequency (I consider ~1KHz to be super low). Ultimately crossover frequency is going to be restricted by the RHPZ regardless of whether CMC is used or not. Voltage mode imposes a little extra penalty, but likely not an issue if you're already willing to accept such a low fc.
But consider AN-57 (which the OP also mentioned), which explicitly states several times that TOPSwitch parts are voltage mode, including transfer function plots showing the classic second order response. Nowhere does it mention current mode control or anything similar to it. It's unclear if this document actually applies to all TOPSwitch families; the only specific families I can see referenced are GX and JX. The JX series, at least, also has contradictory plots showing peak drain current and duty cycle being directly dependent on control current.
Thanks, but yes it does...page 17, top of left hand side text under "Feedback Loop Design"
(the hiphen makes it not show up on 'Control-F' type document searches)
Page 3 (RHS at about centre of page) also declares it as Voltage Mode Control.
Hiper TFS datasheet (Voltage Mode 2 tran forward controller)
...So are you now going to say that Hiper-TFS cannot be made to work in a worthwhile way due to its use of Voltage Mode?
Thanks, good point, though again it depends what your "low" means...the TOPswitch Flyback in DER243 has a crossover frequency of 4.6kHz and its in CCM, Voltage Mode for that. The RHPZ is at 143kHz for this. The Power stage double pole is at 1060 Hz.
So the Voltage Mode, CCM , TOPswitch flyback of DER243 is crossing over more than 3x above the output double pole frequency....as you know, something that would be considered acceptable for Voltage Mode with a Type 3 compensator (which they use).
Thanks, but again we are talking at crossed purposes....The TOPswitch is no longer in Voltage Mode when in light load (ipk less than 55% of imax)
________________----______________
Fig 16, page 17 of the Hiper-TFS datasheet is interesting though.
The text below fig16 says that R21 and C8 provide a zero near the LC
double pole location. This is not correct. To make R21 and C8 form a zero,
the supply through the opto diode must be by way of a voltage regulator.
This is clearly demonstrated in Basso's Book "Designing control....." on pages 424 to 429
You can say its' volt mode above a certain level all you like - the loop crossover performance proves otherwise - above 55% the current into the comp pin sets a ref level for the current comparator - else they would have to switch from one system to another at 55% - this is not efficient or clever design - esp if you then lose the robustness and speed of the 2 loop system above 55% . . ..
once again - a mistake repeated by a junior data sheet / app note writer - does not make it so.
any simple LT spice check using a fixed ramp and comparator , and V out loop only for control of a CCM flyback will show the falsity of the premise.
It appears that app note / data sheet , p17 is littered with errors:
The Zero not being a Zero, and R11 & C5 not contributing - which the definitely do.
mistakes seem to be the order of the day for these writers - who are obviously not the chip designers . . .
but the pièce de résistance must be the 7kHz crossover with > 55 deg phase margin - show me volt mode doing that !
--- Updated ---
actually this is not true - under DCM, volt mode can be much faster as there is no RHPZ under DCM - back to the books for Mtweig.
I love this bit because the output voltage is indeed regulated by a voltage loop, and it is pwm based, CMC is neatly avoided so as not to confuse the newbies
Note the talk of cycle by cycle current limit ( impliedly to perform pk curr mode ) - why have this and not use it down to 55% to get far better system dynamics in CCM ? - are you saying the PI guys literally decided to abandon a superior strategy and skip over to volt mode only - making their product super hard to stabilise above 55% current ? yeah right.
QED.
Thanks, i wouldnt deny that you are only saying out loud deep seated reservations which also exist at the back of my own mind about this.
(Whether Current Mode or Voltage Mode)
Either way, it'd be good to get a solution for the very common situation of being presented with a customer who wants a Flyback design done with TOPswitch....and their spec, etc, means that the Power Integrations software "PI Expert" or "PI XLS designer" cant be used.
So you have to make out the Bodes...because the PI docs say it is Voltage Mode.....but then if it is actually in Current Mode and you use Voltage Mode Tran Func then the Bodes will be wrong.
So what do you do.
You cant even do Current Mode bodes because they dont give you the internal sense resistor value in the TOPswitch.
Basically it would be good to find the "coup de gras" evidence that there really is no way of knowing what the control mode is, and then you can just tell the customer....look, TOPswitch isnt good for you without a PI Expert supported design. ....Because the PI docs simply dont allow one to produce the Bode Plots...and it just might be in Voltage Mode Control.
Ive asked on the PI forum about this, but get little help....i think at the end of the day, their Innoswitch is seen to be the replacement for TOPswitch so "why would anyone want to use TOPswitch anyway"....the Innoswitch being the "be all and end all" of all offline flyback control.....because its perfectly stable and does all the compensation internally...even has the isolated feedback inside it.....and a sync rect driver aswell...plus many of them have zero voltage turn-ON even for CCM....there's even an active clamp version.
Also, maybe the TOPswitch App Note writers at PI indeed dont know whether its in Current Mode or Voltage Mode(?)....so they get everyone to treat it as Voltage Mode, and then whatever feedback compensation they then come up with will likely give stability even if it is indeed actually a Current Mode controlled chip.
Maybe thats also why Basso in his eighth chapter does TOPswitch design examples and considers it as a Voltage Mode controller(?)
--- Updated ---
I must admit I once had a little bit of "time alone" with a TOPswitch flyback PCB (in CCM at low mains).
With little time on my hands, I started banging in and out any old feedback compensation components I could find
lying around so as to try and get it to go unstable when in CCM...thinking that being in Voltage Mode + CCM, i'd quickly be able
to make it go unstable......but I was unable to get instability.....it was just perfectly smooth and stable no matter what
compensation R's and C's (whatever was lying around in the lab) I soldered in and out.
So yes, I am beginning to wonder about the Voltage Mode vs Current Mode thing with TOPswitch.
--- Updated ---
I think what needs to be done is to layout a TOPswitch
Flyback and arrange for it to be in CCM.
Then arrange a type 2 TL431/Opto feedback.
Then make the two feedback compensation zero's at well above the Power stage
LC resonant frequency. Then load step it from no load to full load.
If it rings at the power stage LC resonant frequency then TOPswitch
is indeed in Voltage Mode.
--- Updated ---
Thanks, the attached excel from ti.com shows a LM5145 based Voltage Mode Synch Buck at 100kHz, 48V to 24V at 10A.....crossover frequency is 20kHz, and phase margin is 56 degrees.
So this kind of thing is possible with Voltage Mode control.
LM5145
  • LM5145_quickstart_calculator_A5_.zip
[EDITED as previous excel doc had a typo]
The Bode plots for DER234 [TOPswitch DCM flyback at 230VAC input (DCM) and at 115VAC input (CCM)] came out reasonably similar to the
ones given in the DER234 App NOte.
So maybe TOPswitch is in Voltage Mode after all.
The CCM and the DCM ones, for min and max line respectively, correspond reasonably well to the DER234 ones
when the Voltage Mode transfer functions are used.
DER234
  • Loop Bodes _DER234 18W Flyback TOPswitch_Basso_1.zip
As a manufacturer - why would you issue a part that is hard to stabilise and would cause widespread frustration with your parts - you wouldn't - you would strive for the opposite.
Every engineer well grounded in control theory and application knows the 2 loop system to be far superior in every aspect - PI harp on about the temp stabilised curr signal derived from the internal mosfet - do you think they would go to all this trouble and not use it ?
Any clown can stabilise a PI part - thanks to the internal current loop - which is exactly what they want - general happiness with the parts.
QED.
( p.s. buck is not a flyback with RHPZ, it is a direct action forward converter, you are comparing apples with cumquats )
Thanks, but the Flyback in DER234 (when in CCM on low line input) has its RHPZ at 93500 Hz, so its far enough out of the way not to have to worry about.
Indeed in most offline flybacks, the RHPZ is usually way above 5x crossover frequency.
Thanks but they do use it, they use it in "55% variable freq mode", and they use it as a tight limiting current threshold.
When TOPswitch came out, literally anyone could properly stabilise it by using their PI Expert software, or their PI XLS software.
Thanks but not always better...voltage mode doesnt need slope compensation.
Also, TOPswitch is a "flyback controller which is also OK for beginners"....and they may not do good layout, so its best to make it
voltage mode so the poorly layed out TOPswitch SMPS's have more of a chance. of working.
Thanks, but if TOPswitch were so bad in Voltage Mode, then someone would have brought out the current mode version....but they have not...because Voltage Mode is the way to go for these type of integrated switcher chips. There used to be the FSGM0565, which was current mode, but it went obselete.....i guess Current Mode just wasnt the way to go for these type of Flyback FET/Control chips. Power Integrations chose voltage mode and they have ended up being the winners.
___---___---__---___
Take a look at DER234 by Power Integrations....they have a CCM Voltage Mode Flyback there (when at 115VAC).
The Power stage double pole frequency is 731Hz. So Power Integrations put in compensation zero's
at 188Hz, and at 99.5Hz....compensating out the double poles beautifully.
But wait for the best bit....the way that Power Integrations manage the output double pole
is a master class!...
The TL431/OPTO configuration is Type 2.....so there's usually only one compensation zero to play with.
-But the genius's at Power integrations have got it sorted...take a look at C8 and R9 in DER234 (page 6).
This provides the missing zero.
Voltage Mode is dealt with no problem!
...Not only that, but into the bargain, they have a common collector connected opto transistor...so dont suffer all the delays due to the opto pole.
And theres more still!...they re-use the compensation capacitor, C8, as a supply capacitor for the Chip!
Not only Voltage Mode, but Voltage Mode MasterClass!
DER234
There's no reasoned argument with lack of control knowledge - try building a volt mode only in real life - or on LT spice - as you seem to be keen on it
the results will speak for themselves . . .
Re the 18 watt converter:
you can only get 463 Hz crossover, because it is current mode internally
the same ckt with pure volt mode just oscillates . . .
Post #34 above shows a 100khz voltage mode buck with 20khz crossover freq and 56 degs of phase margin.
I realise its buck but its same for offline flybacks which often have RHPZ well above 50kHz......so they can easily manage crossover of 463Hz
without oscillating.
So you are saying that because of the top of page 3 of the attached, it will oscillate, because the lowest the crossover freq could be is 2.3khz? (if it was ccm, voltage mode)
I would admit that the PI Expert Software or PI XLS software, no longer gives out Bode Plots with any of the designs that it does. Which seems strange.
It always used to.
  • _3 Loop Gain Crossover Frequency.zip
full power CCM is the worst condition for stability for a flyback:
note that 2.pi.F rhpz is proportional to Rload, so the freq comes down at full power.
Note the phase dive - even under current mode !
Compare to DCM ( also current mode ):
Oh yes - the gain of the flyback under CCM does go up pretty impressively with Vin !
--- Updated ---
for completeness, the D to output bode plot, CCM:
In volt mode control - you cannot introduce enough phase lift to make a fast system.
Write your reply...
LaTeX Commands Quick-Menu:
