8051 + AT commands using Nokia phone
nokia 1600 at command guide
Thanks a lot Budhy, I'll try it out and hope to get it done, the 8 lines are 8051 interfacing with IR sensor, nothing much to be concerned about, anyway thank you and sorry for inconvenient caused to you.
Added after 46 minutes:
Wait0DH:
ACALL SerialIn
CJNE A,#0DH,Wait0DH
RET
SerialIn:
JNB RI,SerialIn ;Wait for another character
MOV A,SBUF ;Save it in accumulator
CLR RI ;Get ready for next character
RET
This means I have to receive 0DH instead of the letter 'O' and 'K'? I thought I have to receive an 'OK' from phone?
at commands 8051 code
Sorry but I have another question to ask: I've tried out the program but the phone still couldn't send out SMS, the question is I've measured the voltage drop at pin 10 and pin 11 which is RxD and TxD respectively, but I obtained 0V, is this possible? Shouldn't it be something around 5V?
Another question is that for the capacitors linked with crystal and pin 18 & 19, what value of capacitance shall I use? I've tried 12pF and 33pF but none of them worked.
dlr-3p pinouts
;; ***** you don't need to execute the following 4 lines every time
     MOV   DPTR,#CMGF
     ACALL SingleCommand
     MOV   DPTR,#CSCA
     ACALL SingleCommand
Do it once from HyperTerminal, and don't worry about OK etc...
Normally use 33 pF. Powered your uC then use Osciloscope to check your curcuit, if there is clock stream on ALE (pin #30) it means your circuit is OK.
Are you sure there are 5 Volt on pin 40, and pin 20 connected to ground?
how to receive at commands 8051
Yes, I've measured pin 40, it's 5V, pin 20 is ground, but the RxD and TxD values are very low, what voltage should RxD and TxD have?
mcs51 at command nokia
Is this correct?
at commands nokia 8051
Refer to your diagram,
there are two reason can cause the volatge on pin 11 (TX) of 8051 about 0 Volt:
1. No Voltage between pin 20 and 40 (please measure again directly at that 2 pin)
2. Your 8051 chip is out of order
there are two reason can cause the volatge on pin 10 (RX) of 8051 about 0 Volt:
1. that pin not connected to phone TX
2. Your phone is out of order
At this two lines at top of your program before doing above testing
     SETB P3.0
     SETB P3.1
Do you already test the ALE signal?
dlr-3p at command
SETB P3.0
SETB P3.1
That means I insert these 2 lines and connect the circuit without connecting the phone? Or with the phone? I thought port 0,1,2 and 3 are all high in default? So I still have to set P3.0 and P3.1?
Not yet, the lab is not open these few days because of public holiday, going to test it out later.
Added after 1 minutes:
P/s: What voltage should it be on TxD and RxD? Should they be 5V?
code of 8051 for nokia phone interface
Yes, you are right. Those 2 lines just for make you sure RX and TX is at high states
Test with two condition, with and without the phone
The stand by state of serial transmission line is 'high', so TxD should be around 5 Volt
RxD is prepare for input (you already set RE - Receive Enable bit), so RxD should be around 5 Volt
I doubt your uC chip is out of order
at commands for nokia
I will try it out again when lab reopens, anyway thanks for your help and Happy New Year to you.
I will post my problem again if I meet any.
nokia at commands
I have another problem over here..
I've added an LCD to be interfaced with the AT89S51, but then the output voltage of the 89S51 pin is just 1.8V instead of 5V, which is very very low to run the LCD, why does this happen?
By the way, what is the difference between AT89S51 and AT89C51?
Thanks in advance.
at commands for nokia 1600
Just pull up the pins of the 89S51 and you should be fine. What voltage is the 89S51 operated on.
which nokia phone follow all at commands
What do you mean by pull up the pins of 89S51? It operates on 5V, and should output 5V as well.
nokia 1600 atcommand
The output of 8051 (both C51 and S51) is not a push-pull type output. It is a weakly pulled-up open-drain type output. It can sink large currents (5ma or so) but can source only a few micro-amps. So if you feel that the output is not capable of driving properly, you connect about 4.7kohm resistors between the port pins and +5V.
Alternately, you can use a 74LS244 type buffer.
I have not found much difference between C51 and S51 as far as port pins are concerned.
nokia 1600 tx/rx
wat port are u using?
P0?
nokia phone at command
But as far as I concerned, the port 1, 2 and 3 are already pulled up internally, do we still need to pull them up externally?
P/s: I'm using port 1
issue at commands nokia 1600
As I said earlier, the pullups are very weak. About 50kohm internal pullups. If the output need to drive something that requires more current, you need to pullup like you do on P0.
buy nokia dlr 3p philippines
the 1.8 V pin voltage is measured before or after AT89S51 connect to LCD module?
What is the voltage before connect AT89S51 to LCD module?
At this case, AT89S51 and AT89C51 are totally compatible.
at commands + microcontroller ctrl z enter
1.8V is measured after it is connected to LCD.
I will test it out tomorrow, thanks for helping.
