74hc595 16f877a interfacing problems
So, you need only two 74HC595. Zip and post Proteus file. I write code for 2 x 74HC595 ?
It doesn't display CAPS alphabets and digits 6-9 ?
6 to 9 are also there, but since the audio section plays only 32, so limited the integers to 5,
It will not show caps, we are showing the brainle characters first, since it is easy to show using this. that dont have caps.
The normal state off state of the solenoid is the state which shows the character, when on the solenoid will not show,
so the binary i have send have to be reversed, i will reverse it and send,
we show only one character each time, so i have made the binary for that only, but we have six other characters, so we have to fill it also in on state( not showing character). I will include that also and send. The modified version and the proteus file i will send in shorttime
I will zip the proteus file and send.
we can see the brainle characters can be easily expressed by 6dots
https://encrypted-tbn0.gstatic.com/...t6BwLtTNXGoOSAobNyjG7HxdwgVusS2o3Tk1KrLn_rCeQ
Ok. Check if this code works. There will be only two 74HC595s
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
sbit SH_CP at RD0_bit;
sbit SH_CP_Direction at TRISD0_bit;
sbit ST_CP at RD2_bit;
sbit ST_CP_Direction at TRISD2_bit;
sbit DS at RD1_bit;
sbit DS_Direction at TRISD1_bit;
char uart_rd;
unsigned int value2hc595 = 0;
void interrupt() {
     if(RCIF_bit) {
           if(OERR_bit) {
                 CREN_bit = 0;
                 CREN_bit = 1;
                 OERR_bit = 0;
           uart_rd = UART1_Read();
           RCIF_bit = 0;
void SPI_Send(unsigned long s) {
     unsigned long mask = 0x2000;
     char i = 0;
     for(i = 0; i < 16; i++, mask >>= 1) {
           if(s & mask)
               DS = 1;
           else
               DS = 0;
           SH_CP = 1;
           Delay_ms(10);
           SH_CP = 0;
     ST_CP = 1;
     Delay_ms(10);
     ST_CP = 0;
void main() {
     CMCON = 0x07;
     ADCON1 = 0x87;
     TRISA = 0xC0;
     TRISB = 0x00;
     TRISC = 0x80;
     TRISD = 0x00;
     PORTA = 0x00;
     PORTB = 0x00;
     PORTC = 0x00;
     PORTD = 0x00;
     SH_CP_Direction = 0;
     SH_CP = 0;
     ST_CP_Direction = 0;
     ST_CP = 0;
     DS_Direction = 0;
     DS = 0;
     UART1_Init(9615);
     Delay_ms(200);
     RCIF_bit = 0;
     RCIE_bit = 1;
     PEIE_bit = 1;
     GIE_bit = 1;
     while(1) {
          if(uart_rd) {
                  switch(uart_rd) {
                        case 'a':
                             value2hc595 = 0b10000010000000;
                             break;
                        case 'b':
                             value2hc595 = 0b10100001000000;
                             break;
                        case 'c':
                             value2hc595 = 0b11000000100000;
                             break;
                        case 'd':
                             value2hc595 = 0b11010000010000;
                             break;
                        case 'e':
                             value2hc595 = 0b10010000001000;
                             break;
                        case 'f':
                             value2hc595 = 0b11100000000100;
                             break;
                        case 'g':
                             value2hc595 = 0b11110000000010;
                             break;
                        case 'h':
                             value2hc595 = 0b10110000000001;
                             break;
                        case 'i':
                             value2hc595 = 0b01100011000000;
                             break;
                        case 'j':
                             value2hc595 = 0b01100001100000;
                             break;
                        case 'k':
                             value2hc595 = 0b10001000110000;
                             break;
                        case 'l':
                             value2hc595 = 0b10101000011000;
                             break;
                        case 'm':
                             value2hc595 = 0b11001000001100;
                             break;
                        case 'n':
                             value2hc595 = 0b11011000000110;
                             break;
                        case 'o':
                             value2hc595 = 0b10011000000011;
                             break;
                        case 'p':
                             value2hc595 = 0b11101010000001;
                             break;
                        case 'q':
                             value2hc595 = 0b11111011100000;
                             break;
                        case 'r':
                             value2hc595 = 0b10111001110000;
                             break;
                        case 's':
                             value2hc595 = 0b01101000111000;
                             break;
                        case 't':
                             value2hc595 = 0b01111000011100;
                             break;
                        case 'u':
                             value2hc595 = 0b10001100001110;
                             break;
                        case 'v':
                             value2hc595 = 0b10101100000111;
                             break;
                        case 'w':
                             value2hc595 = 0b01110110000011;
                             break;
                        case 'x':
                             value2hc595 = 0b11001111000001;
                             break;
                        case 'y':
                             value2hc595 = 0b11011111110000;
                             break;
                        case 'z':
                             value2hc595 = 0b10111001111000;
                             break;
                        case '0':
                             value2hc595 = 0b01110000111100;
                             break;
                        case '1':
                             value2hc595 = 0b10000000011110;
                             break;
                        case '2':
                             value2hc595 = 0b10100000001111;
                             break;
                        case '3':
                             value2hc595 = 0b11000010000111;
                             break;
                        case '4':
                             value2hc595 = 0b11010011000011;
                             break;
                        case '5':
                             value2hc595 = 0b10010011100001;
                             break;
                  SPI_Send(value2hc595);
                  uart_rd = 0;
Reactions: varunme
    varunme
it almost works, some irregular bits inbetween, when checked in proteus, will check thoroughly and get back to you
Post a photo of braillie system. Also upload video to mediafire and provide link to download it here.
The system make is not complete, i am just checking the firmware, after checking in led, i will try by making the system,
I have included the binary, i will upload the proteus file in shortime
Sl No	Case	Binary to shift
1	a	100000 1111111111 11111111111111111111111111 10000000
2	b	101000 1111111111 11111111111111111111111111 01000000
3	c	110000 1111111111 11111111111111111111111111 00100000
4	d	110100 1111111111 11111111111111111111111111 00010000
5	e	100100 1111111111 11111111111111111111111111 00001000
6	f	111000 1111111111 11111111111111111111111111 00000100
7	g	111100 1111111111 11111111111111111111111111 00000010
8	h	101100 1111111111 11111111111111111111111111 00000001
9	i	011000 1111111111 11111111111111111111111111 11000000
10	j	011000 1111111111 11111111111111111111111111 01100000
11	k	100010 1111111111 11111111111111111111111111 00110000
12	l	101010 1111111111 11111111111111111111111111 00011000
13	m	110010 1111111111 11111111111111111111111111 00001100
14	n	110110 1111111111 11111111111111111111111111 00000110
15	o	100110 1111111111 11111111111111111111111111 00000011
16	p	111010 1111111111 11111111111111111111111111 10000001
17	q	111110 1111111111 11111111111111111111111111 11100000
18	r	101110 1111111111 11111111111111111111111111 01110000
19	s	011010 1111111111 11111111111111111111111111 00111000
20	t	011110 1111111111 11111111111111111111111111 00011100
21	u	100011 1111111111 11111111111111111111111111 00001110
22	v	101011 1111111111 11111111111111111111111111 00000111
23	w	011101 1111111111 11111111111111111111111111 10000011
24	x	110011 1111111111 11111111111111111111111111 11000001
25	y	110111 1111111111 11111111111111111111111111 11110000
26	z	101110 1111111111 11111111111111111111111111 01111000
27	0	011100 1111111111 11111111111111111111111111 00111100
28	1	100000 1111111111 11111111111111111111111111 00011110
29	2	101000 1111111111 11111111111111111111111111 00001111
30	3	110000 1111111111 11111111111111111111111111 10000111
31	4	110100 1111111111 11111111111111111111111111 11000011
32	5	100100 1111111111 11111111111111111111111111 11100001
How many bits are there in the binary value ? What was the binary values you sent earlier ? How and why did the bits in binary values increase ?
alltogather 42 solenoids are there, but i use 6bits only others are dummy values of 1
and again 8 bits for the voice,
so alltogather only 14bits are used, all other are dummy values of 1
The binary values, i sent earlier was without dummy values
The dummy values are to put the solenoids that are not used to rest
Show your exact 74HC595 connections.
Here is the code. Test it in hardware.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
sbit DS at RD1_bit;
char uart_rd;
unsigned char value12hc595 = 0, value22hc595 = 0;
void interrupt() {
     if(RCIF_bit) {
           if(OERR_bit) {
                 CREN_bit = 0;
                 CREN_bit = 1;
                 OERR_bit = 0;
           RCIF_bit = 0;
void SPI_Send(unsigned char s1, unsigned char s2) {
     unsigned long mask;
     char i = 0;
     mask = 0x20;
     for(i = 0; i < 6; i++, mask >>= 1) {
           if(s1 & mask)
               DS = 1;
           else
               DS = 0;
           SH_CP = 1;
           Delay_ms(5);
           SH_CP = 0;
     for(i = 0; i < 36; i++) {
           DS = 1;
           SH_CP = 1;
           Delay_ms(5);
           SH_CP = 0;
     mask = 0x80;
     for(i = 0; i < 8; i++, mask >>= 1) {
           if(s2 & mask)
               DS = 1;
           else
               DS = 0;
           SH_CP = 1;
           Delay_ms(5);
           SH_CP = 0;
     ST_CP = 1;
     Delay_ms(5);
     ST_CP = 0;
void main() {
     CMCON = 0x07;
     ADCON1 = 0x87;
     TRISA = 0xC0;
     TRISB = 0x00;
     TRISC = 0x80;
     TRISD = 0x00;
     PORTA = 0x00;
     PORTB = 0x00;
     PORTC = 0x00;
     PORTD = 0x00;
     SH_CP = 0;
     ST_CP = 0;
     DS_Direction = 0;
     DS = 0;
     UART1_Init(9615);
     Delay_ms(200);
     RCIF_bit = 0;
     RCIE_bit = 1;
     PEIE_bit = 1;
     GIE_bit = 1;
     while(1) {
          if(uart_rd) {
                  switch(uart_rd) {
                        case 'a':
                             value12hc595 = 0b100000;
                             value22hc595 = 0b10000000;
                             break;
                        case 'b':
                             value12hc595 = 0b101000;
                             value22hc595 = 0b01000000;
                             break;
                        case 'c':
                             value12hc595 = 0b110000;
                             value22hc595 = 0b00100000;
                             break;
                        case 'd':
                             value12hc595 = 0b110100;
                             value22hc595 = 0b00010000;
                             break;
                        case 'e':
                             value12hc595 = 0b100100;
                             value22hc595 = 0b00001000;
                             break;
                        case 'f':
                             value12hc595 = 0b111000;
                             value22hc595 = 0b00000100;
                             break;
                        case 'g':
                             value12hc595 = 0b111100;
                             value22hc595 = 0b00000010;
                             break;
                        case 'h':
                             value12hc595 = 0b101100;
                             value22hc595 = 0b00000001;
                             break;
                        case 'i':
                             value12hc595 = 0b011000;
                             value22hc595 = 0b11000000;
                             break;
                        case 'j':
                             value22hc595 = 0b01100000;
                             break;
                        case 'k':
                             value12hc595 = 0b100010;
                             value22hc595 = 0b00110000;
                             break;
                        case 'l':
                             value12hc595 = 0b101010;
                             value22hc595 = 0b00011000;
                             break;
                        case 'm':
                             value12hc595 = 0b110010;
                             value22hc595 = 0b00001100;
                             break;
                        case 'n':
                             value12hc595 = 0b110110;
                             value22hc595 = 0b00000110;
                             break;
                        case 'o':
                             value12hc595 = 0b100110;
                             value22hc595 = 0b00000011;
                             break;
                        case 'p':
                             value12hc595 = 0b111010;
                             value22hc595 = 0b10000001;
                             break;
                        case 'q':
                             value12hc595 = 0b111110;
                             value22hc595 = 0b11100000;
                             break;
                        case 'r':
                             value12hc595 = 0b101110;
                             value22hc595 = 0b01110000;
                             break;
                        case 's':
                             value12hc595 = 0b011010;
                             value22hc595 = 0b00111000;
                             break;
                        case 't':
                             value12hc595 = 0b011110;
                             value22hc595 = 0b00011100;
                             break;
                        case 'u':
                             value12hc595 = 0b100011;
                             value22hc595 = 0b00001110;
                             break;
                        case 'v':
                             value12hc595 = 0b101011;
                             value22hc595 = 0b00000111;
                             break;
                        case 'w':
                             value12hc595 = 0b011101;
                             value22hc595 = 0b10000011;
                             break;
                        case 'x':
                             value12hc595 = 0b110011;
                             value22hc595 = 0b11000001;
                             break;
                        case 'y':
                             value12hc595 = 0b110111;
                             value22hc595 = 0b11110000;
                             break;
                        case 'z':
                             value22hc595 = 0b01111000;
                             break;
                        case '0':
                             value12hc595 = 0b011100;
                             value22hc595 = 0b00111100;
                             break;
                        case '1':
                             value22hc595 = 0b00011110;
                             break;
                        case '2':
                             value22hc595 = 0b00001111;
                             break;
                        case '3':
                             value22hc595 = 0b10000111;
                             break;
                        case '4':
                             value22hc595 = 0b11000011;
                             break;
                        case '5':
                             value22hc595 = 0b11100001;
                             break;
                  SPI_Send(value12hc595, value22hc595);
                  uart_rd = 0;
The values are split like this, 6 bits, 36 bits and 8 bits for easier sending
1	a	100000 111111111111111111111111111111111111 10000000
2	b	101000 111111111111111111111111111111111111 01000000
3	c	110000 111111111111111111111111111111111111 00100000
4	d	110100 111111111111111111111111111111111111 00010000
5	e	100100 111111111111111111111111111111111111 00001000
6	f	111000 111111111111111111111111111111111111 00000100
7	g	111100 111111111111111111111111111111111111 00000010
8	h	101100 111111111111111111111111111111111111 00000001
9	i	011000 111111111111111111111111111111111111 11000000
10	j	011000 111111111111111111111111111111111111 01100000
11	k	100010 111111111111111111111111111111111111 00110000
12	l	101010 111111111111111111111111111111111111 00011000
13	m	110010 111111111111111111111111111111111111 00001100
14	n	110110 111111111111111111111111111111111111 00000110
15	o	100110 111111111111111111111111111111111111 00000011
16	p	111010 111111111111111111111111111111111111 10000001
17	q	111110 111111111111111111111111111111111111 11100000
18	r	101110 111111111111111111111111111111111111 01110000
19	s	011010 111111111111111111111111111111111111 00111000
20	t	011110 111111111111111111111111111111111111 00011100
21	u	100011 111111111111111111111111111111111111 00001110
22	v	101011 111111111111111111111111111111111111 00000111
23	w	011101 111111111111111111111111111111111111 10000011
24	x	110011 111111111111111111111111111111111111 11000001
25	y	110111 111111111111111111111111111111111111 11110000
26	z	101110 111111111111111111111111111111111111 01111000
27	0	011100 111111111111111111111111111111111111 00111100
28	1	100000 111111111111111111111111111111111111 00011110
29	2	101000 111111111111111111111111111111111111 00001111
30	3	110000 111111111111111111111111111111111111 10000111
31	4	110100 111111111111111111111111111111111111 11000011
32	5	100100 111111111111111111111111111111111111 11100001
I have attached a rough drawing in png format, it was difficult to draw, so it took time, sorry
Attached the proteus file
  • New Project_1.zip
Attached is Proteus 8.1 SP1 format file. Name the gate connections w.r.t 74HC595's output connection names. Add LEDs and then zip and post the proteus file.
  • braille.rar
  • braille.PDF
Modified and attached
  • braille.zip
Only G1 and G2 are named properly. For all others instead of naming the input connector you have created labels and hence the simulation will not work.
Reactions: varunme
    varunme
I have uploaded the corrected one
  • braille.pdsprj.Home-PC.Home.zip
Test the simulation. If it gives errror then remove the mosfets and just check the outputs of 74HC595s.
Use this code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
     unsigned char mask;
     char i = 0;
     mask = 0x20;
           if(s1 & mask)
               DS = 1;
           else
               DS = 0;
           SH_CP = 1;
           Delay_ms(5);
           SH_CP = 0;
     DS = 1;
           SH_CP = 1;
           Delay_ms(5);
           SH_CP = 0;
     mask = 0x80;
           if(s2 & mask)
               DS = 1;
           else
               DS = 0;
           SH_CP = 1;
           Delay_ms(5);
           SH_CP = 0;
     ST_CP = 1;
     Delay_ms(5);
     ST_CP = 0;
Reactions: varunme
    varunme
almost correct i think, have to correct some binaries and update you
In sending a, only one have bit have to be unique in the first 6bits, but all the bit changes, in the 6bits this applies to all.
The last 8bits dont change at all.
