milan.rajik
Banned
- Joined
- Apr 1, 2013
- Messages
- 2,524
- Helped
- 540
- Reputation
- 1,078
- Reaction score
- 524
- Trophy points
- 1,393
- Activity points
- 0
My previous post is updated. What does the solenoids do ?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 unsigned long value2hc595 = 0; char counter = 0, i = 0; char buffer[24]; //MSB sent first void interrupt() { if(RCIF_bit) { if(counter < 24) { buffer[counter++] = UART1_Read(); ++counter; } RCIF_bit = 0; } } while(1) { if(counter == 23) { for(i = 0; i < 24; i++) { value2hc595 <<= 1; if(vuffer[i] == '1') { value2hc595 |= 1; } } } ]
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 void SPI_Send(unsigned long s) { unsigned long mask = 0x80000000; char i = 0; for(i = 0; i < 24; i++, mask >>= 1) { if(s & mask) DS = 1; else DS = 0; SH_CP = 1; Delay_ms(10); SH_CP = 0; } ST_CP = 1; Delay_ms(10); ST_CP = 0; }
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 void SPI_Send(unsigned long s) { unsigned long mask = 0x800000; char i = 0; for(i = 0; i < 24; i++, mask >>= 1) { if(s & mask) DS = 1; else DS = 0; SH_CP = 1; Delay_ms(10); SH_CP = 0; } ST_CP = 1; Delay_ms(10); ST_CP = 0; }
sbit SH_CP at RD0_bit;
sbit SH_CP_Direction at TRISD0_bit;
sbit ST_CP at RD2_bit;
sbit ST_CP_Direction at TRISD2_bit;
sbit DS at RD1_bit;
sbit DS_Direction at TRISD1_bit;
char uart_rd = 0, i = 0, j = 0;
char sequence[12] = {0b11000011, 0b11011011, 0b11100011,
0b11000011, 0b11111011, 0b11100011,
0b11010011, 0b11011011, 0b11110011};
void interrupt() {
if(RCIF_bit) {
if(OERR_bit) {
CREN_bit = 0;
CREN_bit = 1;
OERR_bit = 0;
uart_rd = UART1_Read();
RCIF_bit = 0;
char i = 0;
if(s & mask)
DS = 1;
else
DS = 0;
SH_CP = 1;
Delay_ms(10);
SH_CP = 0;
ST_CP = 1;
Delay_ms(10);
ST_CP = 0;
void main() {
CMCON = 0x07;
ADCON1 = 0x87;
TRISA = 0xC0;
TRISB = 0x00;
TRISC = 0x80;
TRISD = 0x00;
PORTA = 0x00;
PORTB = 0x00;
PORTC = 0x00;
PORTD = 0x00;
SH_CP_Direction = 0;
SH_CP = 0;
ST_CP_Direction = 0;
ST_CP = 0;
DS_Direction = 0;
DS = 0;
UART1_Init(9615);
Delay_ms(200);
UART1_Write_Text("Send 0, 1, 2 or 3\r\n");
UART1_Write_Text("-----------------\r\n\r\n");
RCIE_bit = 1;
PEIE_bit = 1;;
GIE_bit = 1;
while(1) {
switch(uart_rd) {
case '0':
i = 0;
break;
case '1':
i = 3;
break;
case '2':
i = 6;
break;
case '3':
i = 9;
break;
if(uart_rd) {
for(j = i; j < (i + 3); j++) {
SPI_Send(sequence[j]);
Delay_ms(2000);
uart_rd = 0;
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 sbit SH_CP at RD0_bit; sbit SH_CP_Direction at TRISD0_bit; sbit ST_CP at RD2_bit; sbit ST_CP_Direction at TRISD2_bit; sbit DS at RD1_bit; sbit DS_Direction at TRISD1_bit; char i = 0; char buffer[24]; char index = 0; unsigned long value2hc595 = 0; void interrupt() { if(RCIF_bit) { if(OERR_bit) { CREN_bit = 0; CREN_bit = 1; OERR_bit = 0; } if(index < 24) { buffer[index++] = UART1_Read(); } RCIF_bit = 0; } } void SPI_Send(unsigned long s) { unsigned long mask = 0x800000; char i = 0; for(i = 0; i < 24; i++, mask >>= 1) { if(s & mask) DS = 1; else DS = 0; SH_CP = 1; Delay_ms(10); SH_CP = 0; } ST_CP = 1; Delay_ms(10); ST_CP = 0; } void main() { CMCON = 0x07; ADCON1 = 0x87; TRISA = 0xC0; TRISB = 0x00; TRISC = 0x80; TRISD = 0x00; PORTA = 0x00; PORTB = 0x00; PORTC = 0x00; PORTD = 0x00; SH_CP_Direction = 0; SH_CP = 0; ST_CP_Direction = 0; ST_CP = 0; DS_Direction = 0; DS = 0; UART1_Init(9615); Delay_ms(200); RCIF_bit = 0; RCIE_bit = 1; PEIE_bit = 1; GIE_bit = 1; while(1) { if(index == 23) { for(i = 0; i < 24; i++) { value2hc595 <<= 1; if(buffer[i] == '1') { value2hc595 |= 1; } } SPI_Send(value2hc595); index = 0; } } }
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 sbit SH_CP at RD0_bit; sbit SH_CP_Direction at TRISD0_bit; sbit ST_CP at RD2_bit; sbit ST_CP_Direction at TRISD2_bit; sbit DS at RD1_bit; sbit DS_Direction at TRISD1_bit; char i = 0; char buffer[2]; char index = 0, count = 0; unsigned long value2hc595 = 0; void interrupt() { if(RCIF_bit) { if(OERR_bit) { CREN_bit = 0; CREN_bit = 1; OERR_bit = 0; } buffer[index++] = UART1_Read(); RCIF_bit = 0; } } void SPI_Send(unsigned long s) { unsigned long mask = 0x800000; char i = 0; for(i = 0; i < 24; i++, mask >>= 1) { if(s & mask) DS = 1; else DS = 0; SH_CP = 1; Delay_ms(10); SH_CP = 0; } ST_CP = 1; Delay_ms(10); ST_CP = 0; } void main() { CMCON = 0x07; ADCON1 = 0x87; TRISA = 0xC0; TRISB = 0x00; TRISC = 0x80; TRISD = 0x00; PORTA = 0x00; PORTB = 0x00; PORTC = 0x00; PORTD = 0x00; SH_CP_Direction = 0; SH_CP = 0; ST_CP_Direction = 0; ST_CP = 0; DS_Direction = 0; DS = 0; UART1_Init(9615); Delay_ms(200); RCIF_bit = 0; RCIE_bit = 1; PEIE_bit = 1; GIE_bit = 1; while(1) { if(index) { value2hc595 <<= 1; if(buffer[0] == '1') value2hc595 |= 1; index = 0; ++count; } if(count == 24) { SPI_Send(value2hc595); count = 0; } } }
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 sbit SH_CP at RD0_bit; sbit SH_CP_Direction at TRISD0_bit; sbit ST_CP at RD2_bit; sbit ST_CP_Direction at TRISD2_bit; sbit DS at RD1_bit; sbit DS_Direction at TRISD1_bit; char uart_rd, count = 0; unsigned long value2hc595 = 0; void interrupt() { if(RCIF_bit) { if(OERR_bit) { CREN_bit = 0; CREN_bit = 1; OERR_bit = 0; } uart_rd = UART1_Read(); ++count; RCIF_bit = 0; } } void SPI_Send(unsigned long s) { unsigned long mask = 0x800000; char i = 0; for(i = 0; i < 24; i++, mask >>= 1) { if(s & mask) DS = 1; else DS = 0; SH_CP = 1; Delay_ms(2); SH_CP = 0; } ST_CP = 1; Delay_ms(2); ST_CP = 0; } void main() { CMCON = 0x07; ADCON1 = 0x87; TRISA = 0xC0; TRISB = 0x00; TRISC = 0x80; TRISD = 0x00; PORTA = 0x00; PORTB = 0x00; PORTC = 0x00; PORTD = 0x00; SH_CP_Direction = 0; SH_CP = 0; ST_CP_Direction = 0; ST_CP = 0; DS_Direction = 0; DS = 0; UART1_Init(9615); Delay_ms(200); RCIF_bit = 0; RCIE_bit = 1; PEIE_bit = 1; GIE_bit = 1; while(1) { if(uart_rd) { value2hc595 <<= 1; if(uart_rd == '1') value2hc595 |= 1; } if(count == 24) { SPI_Send(value2hc595); count = 0; } } }
Sl No Case Binary to shift
1 a 10000010000000
2 b 10100001000000
3 c 11000000100000
4 d 11010000010000
5 e 10010000001000
6 f 11100000000100
7 g 11110000000010
8 h 10110000000001
9 i 01100011000000
10 j 01100001100000
11 k 10001000110000
12 l 10101000011000
13 m 11001000001100
14 n 11011000000110
15 o 10011000000011
16 p 11101010000001
17 q 11111011100000
18 r 10111001110000
19 s 01101000111000
20 t 01111000011100
21 u 10001100001110
22 v 10101100000111
23 w 01110110000011
24 x 11001111000001
25 y 11011111110000
26 z 10111001111000
27 0 01110000111100
28 1 10000000011110
29 2 10100000001111
30 3 11000010000111
31 4 11010011000011
32 5 10010011100001
