T
treez
Hello,
The Phase Shift Full Bridge (PSFB) converter is a hoax. –The LTspice simulation attached of a “plain” Full Bridge SMPS bears this out.
PSFB claims to be able to reduce switching losses compared to the “plain” Full Bridge SMPS.
However the PSFB does have Turn-OFF switching losses, just as does the “plain” Full Bridge SMPS…so “no cigar” there for the PSFB.
The PSFB does have zero turn-ON switching losses, -but the “plain” Full Bridge SMPS has very minimal switching losses anyway. The only turn-ON switching loss of a “plain” Full Bridge SMPS is that associated with the 1/2CV^2 loss due to the discharge of the FET’s Drain-source capacitance at turn-ON. –But this is a small switching loss.
The “plain” Full Bridge SMPS has no “overlap” of FET voltage and current at turn-ON because the leakage inductance of the Full Bridge transformer prevents the current from rising up quickly enough to do that.
The downer for the PSFB is the large amount of circulating current in the primary of the PSFB transformer, -this causes more conduction losses than the “plain” Full Bridge SMPS…so definitely “no cigar” for the PSFB here.
The PSFB is simply a waste of time, its advantages are too insignificant to make it worth the extra expense. PSFB’s don’t even manage to get zero turn-ON switching losses when lightly loaded. Waste of money…do you agree?
PSFB actually has more dissipation loss in the secondary side diode snubbers than a “plain” Full Bridge SMPS, -Due to the enhanced leakage inductance of the PSFB tranformer. Why is anyone using PSFB?
You can’t even use PSFB at high frequency (like most resonant converters), because the leakage inductance robs you of duty cycle at higher switching frequencies.
