RMMK
Full Member level 3
This is the circuit i am working around with.......
Sir the transmitter is drawing some 0.25Amps of current @ 5Volts input! transistor pin readings for transmitter as read from DVM is shown below (on normal operation):-
I provided some 12Volts to the transmitter and 5 volts to the receiver. The transmitter drew around 0.3Amps from the supply. Also when i placed the transmitter too close to the base of the whip antenna it showed some signal reception at maximum gain position on the preamplifier on the receiver. When i push the potentiometer knob on drain of BF998 to the minimum or mid position no signal gets received......... i think my transmitter is again oscillating at wrong frequencies....... what do u say??
I removed the 27pF and 500nH capacitor and inductor in parallel from Q5 (2n3866) from the transmitter and in place of it placed a 5.6uH inductor. The range now stands at 2feet with the 2N2219 transistor getting warm......
Also i built a very simple diode probe on a breadboard as shown below:-
I placed the diode probe before the antenna on the transmitter that is after the low pass filter and observed a potential difference of around 1.2Volts..... so i think the peak voltage would be around 1.8 V considering the 1N4007 barrier voltage of around 0.6-0.7V
Please help!
Please help!
