- Joined
- Jul 4, 2009
- Messages
- 16,632
- Helped
- 5,158
- Reputation
- 10,349
- Reaction score
- 5,245
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 140,755
Actually, none of them are regenerative receivers! - they are SUPERregerative receivers. Similar circuit but a different way of operating.
The first link dates back to the 1960s and uses vacuum tubes and germanium transistors (silicon transistors were hard to find back then!). The other links are more 'recent' but seem to be based on the parts available at the time rather than being designed for repeatability. The description of how they operate is misleading at best, a superegerative receiver is a an oscillator running at two frequencies, one the signal frequency and the other the 'squegging' frequency which is usually just above audio range. You will note that on all of them the antenna is connected directly to the tuned circuit which has two drawbacks, first is it radiates some of the oscillation and therefore causes inteference nearby, second is the proximity of the antenna to other things nearby causes a tuning shift.
The base capacitor serves two purposes, it has to be big enough to ground the base to RF and it also has to set the time constant for the squegging. I suspect in the designs with electrolytic base capacitors are quite unstable at RF!
Brian.
Brian.
