as far as wire antennas are concerned, any of the NEC stuff are really good... especially NEC-WINPRO... i worked on it and its a breautiful implementation of MoM( Method of Moments)...
hey i dont know if NEC can really be used for planar antennas.. all i have used it for is wire element antennas.. has anyone here done some planar antennas with NEC??
using MICROSTRIPES, 3D EM Solution (Transmission Line Matrix (TLM) method to solve Maxwell’s equations in the time domain) it provides me an easy way to set up my design and its solver is fast and gave me great accuracy. (do not need to master meshing too - like that)
I invite you to try it..
hope this help you, good luck
I have to model the near field of the antenna of RFID reader. The aim of my project is to see the influence of the antenna dimensions and the electrical parameters on the shape and the values of the magnetic field.
I hesitate between Ansoft HFSS and CST MWS. But I saw on the web site of CST that an example of RFID reader has already be done.
So for the moment I think that I should use CST. Is it a good choice?
I would like a soft which is performant but not too complicated I don't have so much time.
In addition could anyone give me approximately the price of CST MWS and HFSS ?
And last question should I also take Agilent ADS with CST ?
Have you ever try Microstripes? I think this one is powerfull enough. This program using 3D GUI. Microstripes is faster than HFSS. The 3D GUI is more user friendly than HFSS.
hi all,from my trying simulation under xfdtd,hfss,ie3d,cst,ansoft designer,cst is the preffered one by more facilites in the design and more friendly software,more fast than xfdtd,but the cst and xfdtd are the more acurate to the measured results
regards
hey,
i downloaded sonet from its website...but its not allowing me to change some of the paprameters ...like i can't change the parameters of metarial properties....help plz
