mtwieg
Advanced Member level 6
In a sense, that's correct. The bootstrap current, the magnetizing current, and the lower freewheeling diode share a junction, so you can draw the currents flowing anywhere you want, so long as they sum to zero. I think most people would see the bootstrap current passing through the freewheeling diode, which can happen so long as the magnetizing current is larger, so that the net current in the diode is positive and it's forward biased. Both views are equally valid.thanks, but you do agree that the bootstrap cap does not recharge via the lower freewheeling diode, rather, it recharges via the magnetising current going through the primary and then on thru the hi-side freewheeling diode?
