Orson Cart
Advanced Member level 3
- Joined
- Jun 18, 2009
- Messages
- 798
- Helped
- 347
- Reputation
- 1,146
- Reaction score
- 558
- Trophy points
- 1,373
- Location
- New Zealand
- Activity points
- 5,973
Hello Treez, most engineers would say that an air gap is not required in a fwd or full bridge or push pull Tx.
reducing the gap to zero maximises the Lpri, which minimizes the Imag, usually a good thing, [except in resonant converters]
If you are running a core up to Bmax (not usually a good idea) then you may need a gap to prevent saturation and the peaky increase in Imag at full power and high temps, this also often happens as Vin goes down and ON time goes up to compensate, the reset time (& voltage) is suddenly too small, and the Tx walks up to Bmax with peaky Imag currents.
Better to design a Tx for a FWD so that none of the above happens, therefore you need control that limits max ON time and a decent amount of Voff to reset the Tx in the OFF time available, also a small amount of slope comp is needed near 50% else you will get 1:2:1 or 1:3:1 oscillations that ramp up the peak current well above design max.
