Transistor tester schematic IC
elektor transistortester
Hi FoxyRick,
I am interested in the Elektor Smart Transistor Tester.
Can I know where to get a the source code for the PIC? Because I cannot find any PIC code as you mentioned. Is the schematic works? I need to know for refering for my final year project.
Thanks for your kindly reply.
in-circuit transistor tester
the company for europe is in france, near paris.
their web site is :
but is in reconstruction
you can mail the author at info@mwinstruments.com
regards,
déterminator 4001 source
largosoft
Where could I find the schematics of the first version (T4001)?
Chris zhi
I am interested in the Elektor Smart Transistor Tester. Can I know where to get a the source code for the PIC
Go to This forum and download nided files from rapid.
no of pins in transistor indicates
Hi All
pavelbo
thanks for your reply
hello;
the sc analyser 2005 is very good , but I would like if there are a new soft for 16F876 to programm .
thanks
how to know e b c of transistor
Transistor testing very simple, it's not need a IC to test it. You can measure by VOM or DMM
lcd transistor identifier
Hi ;
The semiconductor analyser sca2005 programmed with soft "SCA2005-V10-1.HEX" can measure transistors,jfet,mosfet and diodes ; but it can't identify scr (like triac, thyristor and ujt) and darlington and transistor-with-diode .
I ask if there is a new soft ( hex file ) for 16f876 .
Thanks .
peak transistortester
Sorry , but whre is the scheme of "determinator 4001 transistor" project?
I found only codes, pcb and infos .
Thanks
Frigo
scr transistor tester kit
I have a scheme of " determinator 4001 transistor " but which software I must use ?
Excuse em for my English...
Thanks
avr-transistor tester rapidshare
Ich weiß jetzt nicht, ob das Thema noch aktuell ist, aber ich habe vor einiger Zeit mal einen Transistortester gebaut und hier vorgestellt:
https://www.mikrocontroller.net/articles/AVR-Transistortester
Die Features:
- Automatische Erkennung von NPN und PNP-Transistoren, N-und P-Kanal-MOSFETs, Dioden (auch Doppeldioden), Thyristoren und Triacs.
- Automatische Ermittlung und Anzeige der Pins des zu testenden Bauteils
- Erkennung und Anzeige von Schutzdioden bei Transistoren und MOSFETs
- Ermittlung des Verstärkungsfaktors bei Transistoren
- Anzeige der Werte auf einem Text-LCD (2*16 Zeichen)
- Ein-Knopf-Bedienung; automatische Abschaltung
- Messung des Verstärkungsfaktors bei Bipolartransistoren
- Messung der Gate-Schwellspannung bei Anreicherungs-MOSFETs
Ich habe dieses gerät vor so 3 Monaten gebaut. Seitdem konnte es mir schon oft gute Dienste bei der Reparatur von Schaltungen leisten!
Wie üblich ist dieses Projekt natürlich komplett Open Source.[/url]
Re: avr-transistor tester rapidshare
Die Features:
.[/url]
How to program atmega8(Avr-transistortester)? I need Simple schematic?
Thanks.
www.istrianhouse.com
