Transistor tester schematic IC
74hc4052 application
Hi michel95,
Any progress with the Testor?
Regards
download epe august 1998
Michel95,
I am interested in your transistor tester. I was thinking of buying the Peak Atlas tester, but yours may be better. I have a few questions:
1. Can you give a comparison between yours and the Peak Atlas?
2. Is (or can) your LCD display in English? (if there is any actual text anyway)
3. I understand you do not want to release the code, but what about fixes/updates?
4. Would you supply the schematic and PCB diagrams with a programmed PIC, so I could make my own?
Cheers,
FoxyRick.
16f876 transistor tester
Hi
For God sake someone give the schematic or atleast the component overlay digrame of the pcb at this time I only have the pcb image from the orignal site
how to measurement the transistor ebc
naseerak said:
Hi
For --- sake someone give the schematic or atleast the component overlay digrame of the pcb at this time I only have the pcb image from the orignal site
pm michel95 and he will help u...
transistor tester epe
For US and canadian residents go to www.m3electronix.com
For others www.mwinstruments.com
The instrument will be available in kit in Europe on January 15th. You can download datasheet and all specifications.
Regards
Michel
sc analyser transistor
That is great but is there an upgrade for the origional circuit? I mean software upgrade?
Regards
how to find pins e b c npn transistor
If you have been following this thread tehn yes there is a software upgrade the PCB is still the same and theres an add on for opto-isolators and you will aslo would have noted that the hex file is no longer available as it has been sold in kit form.
wizpic[/quote]
ujt tranzisztor model
wizpic
[/quote]
Yes I have been following...where can I get a preprogrammed pic with latest features?
product year 2007 transistor ujt
you buy the complete kit from the above links
i'm sure they dont just supply the pre-programmed pic only kit form. wizpic
tranzistor 1346
Hi! I apologize myself for the quality of my English...
1) Is this forum still active?
2) Where could I find the schematics of the first version (T4001)?
Thanks in advance!
AngusMG
semiconductor analyzer 16f876
Thanks for this great project !!!
As I understood it, the new firmware will be also sold as programmed chip only.
I am looking forward to build such a cool tester this weekend.
I hope the enclosure will be available again soon.
Cheers
Rubi
sca2005-v10-1.hex
Thanks in advance!
:sm39:
scr/triac tester project
HI Michel95
You have been so great to all of us
Thanks Again
transistor tester & elektor
HI Michel95
Project v4.0 hex?
how to use a it-10 transistor checker
Am I right in thinking that this project has just been published in Elektor?
Shame I have just stopped liking them!
FoxyRick.
mwinstruments is down
yes right just published by elektor, or elektuur dutch version, i have seen "demonstration" on rosmalen /s'hertogdenboch nederland elektonic's market's bargain on 19 march, price for board and programmed pic about 30 euros.
m.waleczek@instruments.com
Would be interesting to know which software version is published in Elektor.
I dont think it is 1.4 but I can be wrong.
This is also the first Elektor project I know where only the hex file is downloadable,
but no source code.
Cheers Rubi
2n3094 transistor
Looks like version 1.0e from first february in 1985.
t4001.hex
Rubi:
It's Rev 1.3, the same file that is available for download here on the EDA board. There are a few differences in the circuit itself in the Elektor article. They used a different display which required adding a couple of capacitors and a resistor.
déterminator 4001
Hi Mike Ohio
Oh I see.
Because 2 month ago I bought from Mike95 the Revision 1.4 .
He was so kind to sell it too me without the kit.
It would have been a little annoying, when the same revision is now free for
download from Elektor.
But anyway this great transistor tester was definitly worth the investion.
Btw. did you know that the tester even recognices germanium transistors !!!
Unbelievable five stars for the developer.
Cheers
Rubi
