This is a working RS232.... ICD2 !!!!
I have the same problem if using > COM3, using <COM3 everything works fine. U can use both baud rates.
Hello,
Where is the PCB board for ICD Clone Version 2.3 SMD, in protel format or PDF.
Best Regards,
Jose
Ibiza
I want the single PCB of CrazyDuck's ICD2-RS232 ,anyone help me !!!
I COULD ANYBODY UPLOAD THE ICD2 SCHEMATIC AND PCB IN ORCAD VERSION I COULD NOT OPEN THE PROTEL
APPRECIATED FOR ANY REPLY
OK,
I have DXP 2004 and Orcad library file can open files Orcad layout file *.max and *.llb.
I like the ICD2 Clone v2.3 SMD 2004 I believe that this pcb this one very well.
Regards to the whole group
Jose
Ibiza
A simple question to everyone ...
will it be TOO much costly, if i order a readymade from the website ?
if yes, the pleas tell lumsum, how much would it cost to me if i spend
my mony and time to build it at home ( i have not too much experience/equipment for SMD things).
regards-
Hello,
Someone has the ICD2 Single Layer (one side) with the PIC16F877, I need the PCB, in format protel better or PDF, it does not matter.
Regards
JOse
Hello
What kind is the componement " RDAMP " in the schematic.
Tank you
Good day,
In crazyduck's ICD2, can i just use 7407 instead of 74LS07, its because it's difficult for me to obtain it here in RP. Will the use of 7407 affect the programming/debugging capability of the ICD2 compared to if you use 74LS07?
Thanks
You can try with 7407, probably it will work.
CD
myown said:
I use 16F876A, MAX232, and 3 bipolar transistor - work fine.
Hi myown
I'm very interesting in that too! Can you send it information to me?
Thanks !
MYDIY
Added after 10 minutes:
Regnum said:
Acinfo32,
Both firmware and MCU you're using are wrong.
You must use a 16F877A, and the firmware "BootLoader" attached by Zaphod42 in the first page of this topic.
Hi frieng,
Can i use the latest firmware in MPLAB 7.01?
Thanks
MYDIY
Hi CD,
Can I replace P mosfet with normal transistor and how do I replace , in my location ,i can not find FDS4435,SI4435 or HAT1026,
Try it, but current consommation on base will be great as mosfet.
CD
Hi kdtxwx
i downloaded the schematic of ISD2 in potel 99se format from page 2 of "This is a working RS232.... ICD2" but some capisators and resistor values are not writen, im writingthe component designotors bellow :
Please let meknow the values of the Bellow components.
Thanks in advance
Hi CD,
I just want to ask you what is the characteristics of the FDS4435 that made you choose it in the ICD, so that I can choose the proper replacement for the transistor since it is unavailable at our place. Is it have to be a power P-MOSFET, or can handle large currents, or must be with low channel resistance? Thanks.
You can use any P-MOSFET you want. I use power mosfet, because my ICD2 give the pwer supply to the debug board.
CD
CD,
i build a icd2
.it programs the target pic very well,when i release the reset , taget runs.
but after i using it in debug mode, i connect icd2, it's ok,and i press the menu , debugger->program
the message:
MPLAB ICD 2 Ready
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to target
Target Device PIC16F876A found, revision = b4
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 Ready
Programming Target...
...Erasing Part
...Programming Program Memory (0x0 - 0x7FF)
...Loading DebugExecutive
...Programming DebugExecutive
...Programming Debug Vector
Verifying...
...Program Memory
...Debug Executive
...Debug Vector
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Succeeded
Connecting to debug executive
ICD0083: Target not in debug mode, unable to perform operation
MPLAB ICD 2 Ready
the config of taget pic 876a is 0x3f39 means that fuse is all right. I have read the taget 876a, the fuse bit "DEBUG"is enable. so i cann't find anything will cause this, plz hel p me on this !
...It means your compiler must add add some debugging stuff to the code.
I'm using CCS-C compiler, so I gotta use the following preprocessor command:
#device ICD=TRUE
I dunno what compiler you're using... so check the user's manual.
That's all.
Regards,
Regnum
Hi kdtxwx
Thanks
What other PIC devices in which this RS-232 ICD2 can be used with aside from PIC16F87X? Can it be used for the PIC18F devices? Can it be used also to debug PIC programs written in C through compilers like PICC?
Thanks.
