simce said:I've bypassed HC126 buffers, and problem is solved.
A think it is not needed since i have still using 330 ohm from MCU to target connectorAlso you can try mount 33R - 82R resistors after buffers as partial series termination.
ColdFire said:Hi All,
Have anyone used the ICD2 from this link https://icd2clone.narod.ru. Can I use it with a 3.3v target and 5v target with MPLAB 6.6. Please advice. Thank you.
Regards
mabbri said:In original ICD2 **broken link removed** from microchip when the resistance of MCP41010 is at its highest value Vprog is at its lowest value and viceversa, but in CD´s design when the resistance of MCP41010 is at its highest value Vprog is also at its highest value and viceversa.
Can anyone explain that?
joe123 said:Hello All... Now I hope I dont get shot for asking this question....
Ive decided to build an ICD2. I have read and read this forum up and down and gotten a fairly good understanding of what I need to do..
1. I will be using a 16F877A thus I must program with BootLoader.hex (also known as BootLoader16F877A.hex). WRT set to enabled and HS as the oscillator configuration. I can then automatically update with new frimware from MPLAB.
2. I have a set of about 10 different schematics downloaded from this and other threads. Unfortunetally, I cannot make sence of which one is the most curent and functional (I now many of the early versions had minor errors which were copied into other members versions). I am not interested in USB since it is too hard to get a hold of the Cypress USB IC.. Can someboody PLEASE direct me to the most current shematic..
Below are some of the schematics I'v found.
Regards: Joe
nightmare3ihut said:Testu,thi ICD2 from //.narod.ru use PIC16F876,is it work? what about the bootloader for it?is the file ICD661.hex?
crazyduck said:Hi,
I've realized two ICD2 boards and the both work fine. I've test some voltage points and I found this:
~10V at the input of LM317 and 12,7V at the output.
You must have to program your 16F877A with the correct firmware (look on this topic)
CD:°
