David_
Advanced Member level 2
d123 no I meant Digital Power-Conversion for the Analog Engineer, though they seem to be talking about sort of the same things.
I have just begun to really grasp the extent of research and new learning that this project will require to reach the end result sought after, but that only means a longer time until the start of the real fun though more of it. Unless I would run into some really difficulties in learning things, but I think that I'll be able to make something work.
I think that in order to reach a desirable time frame for the procedure of getting the coils up to the set temperature one needs to apply more power than the power which would result in an equilibrium between the desired temperature and the power applied, at least this is how I see it but I may very well be wrong about this.
If we assume that the coils is at room temperature(≈25C°), what one... "I don't know the English word for one satisfying inhale of a cigarette/smoking device is" requires to happen is in my case the following:
I can with my device specify a temperature and a wattage value, the device is displaying also the resistance of the coils and the current supplied to them(though that value doesn't update fast enough to be able to tell anything of the actual procedure of the algorithm) though the temperature is displayed so that one can with a not very comfortable position watch the temperature rise/fall but that is also at such a slow rate that it doesn't revile anything really interesting.
So I set a temperature of 220C° and a wattage of 55W with coils adding up to 0,27Ω, when I press the switch the current is ramping up to 13,5A and then falls to around 13,1A(there is no way ow telling how accurate these values are, all I know is that while comparing to examples of this device side by side the values didn't agree between the two devices and relating to a single device the numbers doesn't always match with each other, some inconsistencies may also be present. When I first got this device I spent some time observing the values and then making my own calculations to check them and they weren't always correct... When buying rather cheap electronics from China you never know what the quality will be like), I can also see the wattage number climbing.
Then when the temperature is reached the current drops along with the wattage and then for the remainder of the inhale those numbers jump up and down.
Though with this particular setup with these settings the values is pretty consistent but if I for example lower the temperature setting then the values will first overshoot much more before the settle around a lower value(s).
I take this to point to the need for a higher and sometimes much higher initial power applied to the coils, followed by a control loop action applied to maintain the set temperature. And I feel rather confident that I can achieve a better loop than my current device has.
Because after the initial climb/shoot over when the values have settled to it's lower range they still jump up/down quite a bit and it is enough so that I can feel the vapour production increasing/decreasing with them, and I believe that with my own design I would have to begin with better capabilities to perform better, which is the main advantage I see my self having compared to these commercial produced devices.
Giving what have been written since my last post and my self pondering the ideas around this project I think that I will probably stay with XMEGA(the future is going to be interesting given Microchips purchase of Atmel), there is so much other stuff to learn and relating to ice-creams I think XMEGA will taste just fine. I wouldn't want to switch platform if I don't have to so I guess I will wait until XMEGA proves to be insufficient which will probably not happen.
