Radiated susceptibility problem-PWM dimming
If this does not work, you need to look deep in the op-amp side. Power supply impedance is too high OR power supply is having too much voltage ripple.
The question is high much ripple is acceptable at the op-amp stage? I do not know but you have to dig. and dig more.
Adding capacitance to the power rail that feeds the op amps should fix the problem, isn't it?
It is tested in a test house, and the level of light dims and it is visible by the human eye.
