Winsu
Full Member level 3
Hi all,
I have a product which is failing in radiated susceptibility. It is a lamp which is dimmable by a PWM input. When the test is done the flickering is noticeable. I have already shorten tracks a bit and it has improved quite significant but it is still a problem.
The PWM circuit is as follows:
-A shielded cable, a terminal block to connect the PWM input cables on the PCB, an optocoupler to isolate and to convert the signal from 24V to 5V, a comparator(op amp), a TVS ( for transient), and RC network to average the voltage, a voltage follower, after this there is another op amp configured as non-inverter amplifier with an specific gain to adjust for the analogue input of the LED Driver. The order I have announced the components is the order as how they are connected.
-An RC filter was put before the optocoupler with no good result. A capacitor was connected in parallel with a resistor that was already on the design in the non-inverter input of the comparator in case it could filter out the noise, and it didn't do it. Those modifications didn't bring any good results.
-A fixed voltage ( DC) was applied on the comparator ( first op amp) to set the lamp at 50% and the test was carried out. No flickering was seen.
-The tracks after the first op amp are super short, so I don't think noise is coupling after that, but it could be. The RC filter that I mentioned before had a cut off frequency of 2Khz ( the PWM is 1Khz) and it didn't work, so I assume the problem comes from a low frequency. The carrier frequency of the wave radiated is 8Hgz and the modulated is 400Hz,this is as well why I think the problem comes from a low frequency signal. I could put a high pass filter but the cap in series on the PWM line would convert the signal in positive and negative as suppose as the PWM signal is ( referenced to cero, as my op amps are).
Any one have any idea of things I could try.....?,
Thanks a lot!,
Winsu.
Thanks a lot!,
Winsu.
