Question on analog passive filter optimization
poorren
Junior Member level 3
Folks,
Here's a bandpass filter with upper/lower corner frequency around 30Mhz/3Mhz. Because the bandwidth is much wider than center
frequency, it actually constructs by cascading a 30Mhz lowpass with 3Mhz highpass. The simulated response meets my expectation.
However, when trying to implement that filter, I want to make a bit optizimation on that big inductor (2.2uH) and small cap
(10pF/22pF). Yes, I could do nothing but directly implement them. It's implementable.
My question is whether there's some method to convert shunted series-LC section or series shunted-LC section to some more
convenient value. I know the norton transform has the ability to simplify circuit, however, I don't know if it could be applied to these structures.
Do anyone have some suggestion on that? Thanks advance!
The most simple and most direct method would be to insert your filter requirements into a design program for passive filters.
I can recommend AADE from aade.com. It`s freeware, very versatile and you can choose the impedance niveau as you like..
