Tahmid
Advanced Member level 6
- Joined
- Jun 17, 2008
- Messages
- 4,764
- Helped
- 1,799
- Reputation
- 3,590
- Reaction score
- 1,663
- Trophy points
- 1,413
- Location
- Berkeley, California
- Activity points
- 30,739
Without knowing further details, I would have to say that the drop is due to switching losses. I'm guessing you didn't use the totem-pole drivers and just attempted to drive the MOSFETs from the SG3525. Try with the totem-pole drivers and then post the results.
Hope this helps.
Tahmid.
At higher frequency switching losses are higher. You have witnessed this through the voltage drops at higher frequency.
Use the totem-pole drivers and test with 50kHz. You can then adjust as required. 50kHz should be good.
Hope this helps.
Tahmid.
