tahmid , i have also read about SPWM, one thing that i want to know is ..What level spwm can we generate using PIC, i.e. (2nd level, 3rd level etc)??
thanx tahmid
that fault is resolved now,,there was a problem in my wire that connects the battery to the circuit.wire was too thin to drive the 10 amp current ,, as i replaced the wire with a thick one ,,100 watt bulb glowed ,,,![]()
but there is still a small problem- At the transformer output i have used a bridge rectifier using ultrafast HER503 diodes and 400V 47uFD capacitor, when i measure the output voltage with NO LOAD the voltage is around 560volts, but when I connect 100watt bulb ,the output dc voltage goes to 227volts. and when i connect 2 bulbs of 100watt each then output voltage goes to 130volts. till now i havn't used any feedback ,so i want to know where is the problem? is there a problem in my transformer ? my turn ratio is around 35,, and ETD44 core can handle around 450 watts but in my case it cannot handle 200watts,, so please tell me where is the problem??
Hi tahmid
I have used an iverter battery ..I.e. 12v 150ah
Battery voltage is not droping...
Is there any problem in my transformer..I hve wound the primary winding by twisting 12wire strands of 25 gauge..together...I m confused whether I should twist all the wires or just keep the wires parallel as it is....please suggest me...
