fusion2344
Newbie level 3
Surface mount version of ICD2 Clone
I made a SMD version of the ICD2 Clone (PiCS Rev. C from http://www.icd2clone.com/wiki/Main_Page) using TQFP packages.
The device enumerates and drivers install successfully. MPLAB detects the programmer and the yellow LED (BUSY) switch on but then it looses communications.
I double checked the schematic and layout and all seems fine. The pin numbers for the TQFP and DIP packages differ, so I assigned the functions by the pin name (ex. RA0). I don't know if the functionality of certain pins moved with the package change.
Why would MPLAB loose communications with the programmer. If needed I will provide the schematic an layout.
