imar
Full Member level 1
replace pmos nmos
hi freinds!
i found some problems duriny=t the design of a Low Dropout Regulator:
this regulator should have: Vdropout:0.5V, so with Vin 3.3V , Vout must be 2.8V.
the load resisttance goes from 28Ω to 2.8KΩ. the Load capacitor is 2.2µF
this regulator has : * a PMOS pass element W=6µ/L=1µ.
* Error amplifier with 60 dB
* bandgap 1.2V
* a frequency compensation scheme
i designed each element apart, and i verified the functionnality of it.
But, when i reessemble the circuit, the circuit goes nice with load resistance of only 2.3KΩ to 2.8KΩ ( current about 1 to 20 mA approximatly).Ifound that Vout is 2.8V and the stability is about 50° as phase margen.
However, if the Rload falls to 1KΩ or less the regulator ceases to work; infact Vout become 3.8V (which means, i think, (Vin)3.3V + (Vdropout)0.5 V) and the circuit is not stable.
is it about the pass element or some thing else?
thanks in advance for any response that may help me!
hi freinds!
* bandgap 1.2V
