karesz
Advanced Member level 5
I think your problem is, that the output has "shorted" only until 100+/-2.5 msec (as specified) as "the output pulse", & these max 100 times in a hour if you have had 1KWh!
Anyway, you can go (I think) up to ca. 60A=12KWh, or good 1200 pulses pro hour ...
I remember so that you have a power-meter with 100 pulses/KWh= in a hour you will count max 100 pulses(shorts from output transistor), but you told me yesterday over 5 houres measuring time for a 1KWh, it means you have at 200W load, concrete its a 200Wh load, you have also only 20 pulses pro hour, in all 3 minutes (only)one pulse...
These means you must trigger the scope (eventually for "single events") & at some higher trigger levels, i.e. +2, volts, so will you not see these such mV noises(an open measurement input), but a right pulse if outs coming(with time scale of 50--200msec), 2V/div settings...
K.
K.
