karesz
Advanced Member level 5
Hali,
If you will make a product with switched mains voltage, than (in my opinion) you MUST HAVE EXACT SAFETY DATA over the relay(you must know it)_or must select another type!!
I dont no which contry are you from, the actual safety regulations are important to know for you!
For me is important to know, is it really a 230V relay, with enoiugh isolations/crepage distances!?
Is in your contry a mus (maybe is not) to have a so called "safety relay"(they have defined position after mains loss)?
In all cases I WOULD apply an ISOLATED DRIVER from your uP to the relays transistor_or even the RELAYS COIL MUST BE ON LOW(DC?) VOLTAGE, i.e. on the same as your uP!!
Shorter said: I believe that you need another relay to select...
K.
K.
