PicKit 2 FULL with TH components - Need help with layout
can we use ICD2 to program pic18fXXJ50 devices instead of pickit 2?
---------- Post added at 09:29 ---------- Previous post was at 09:19 ----------
hi, can anyone provide me with pickit 2 schematic and pcb files without SMD components...those r not available locally. thanks
yes. the PCB layout is in this forum both smd and non smd :)
Reactions: azaoth
    azaoth
they are right here by Nishal
Only issue while soldering check pin-out of transistors and FETs, if needed swap pins.
One loop was missing i shall indicate, you can change it at pcb stage itself by marker pen
the said changes are indicated in the attachment
can some one post a working ckt of pickit 2 lite? i am getting confused with the different schematics uploaded...i just need it to program my pic offline... thanks in advance
Here is the one you were looking for. Cheers and good luck
If you are referring to microchip pickit2, perhaps NO.
. however you do calibrate the picit for 3.3V , but, instead you may have to configure external Vdd. i didnt get a chance of programming a 3.3V device, though.
Perhaps the User guide describes the situation
Hello.
There is my full PICkit 2. Scheme comes from here: **broken link removed**. I make PCB with normal transistors. Dimension PCB is: 6x10cm.
  • EAGLE.rar
Hello.
this schematic lacks few resistors like 4.7K at the output to ground for clock and data pins. these are needed for some functions as per the pickit2 user manual.
perhaps the designer has skipped them for reasons known to him
Hi mvs sarma..
So do you guys have a fully working PicKit 2 through hole version now? Im a newbie, i really need to build this programmer. Can you pls post a working version here?
Thanx
Here is one :
  • PICKIT 2 Clone.rar
@ john blue
The schematic you have posted is not the full version as i can see. BTW thanx for your post.
---------- Post added at 10:14 ---------- Previous post was at 10:10 ----------
Do you have the full version (through hole)? if so pls share it. Thanx
@ john blue
Here it is: version from mvssarma
  • Pickit_version 2_lay.pdf
Reactions: omega6
    omega6
@ john blue
Thanx alot for the schematic. BTW is it fully functional? i mean PTG and voltage calibration and other stuff. Sorry for these stupid questions, just need to make sure everything is working before buying the parts and all.
Thanx
@ john blue
Once again thanx alot for your help and answers. :smile:
Hey Guys..!!
Im unable to find the BS250 and other SMD parts mentioned here. So im using IRFI9Z34G for P-Channel MOSFETs. The original IRLML6402 has RDS(on) = 0.065ohm and the NTD20P06 has RDS(on) = 0.130ohm while the IRFI9Z34G has RDS(on) = 0.14ohm. So will it work in the programmer?
Thanx..
Data Sheet attached below..
  • irfi9z34g.pdf
Hey Guys..!!
Thanx..
Can you try? should not be problem
At the outset i should thank mahesh holla, of Bangalore, India, who helped me bring this pcb to the ver2 level. Farnell sells IRLML6402 and it is not costly. alternately SI2302 is available in SOT23
compatible
the artwork we tried and used smd as BS250 has higher ON resistance at 10 ohms and it was problematic
we did not want to make the unit bulky by using TO220 devices.
