[SOLVED] pic16f72 sinewave inverter with asm codes. not working.
sudipmuk said:
If u can give the schematic i can build u code for it. atleast give the functions of the pins of PIC , like which pins are controlling the mosfets , is it active-high or actiive-low .. etc.
Sudip, i think i'll expect your help in re-building the code for the said inveter. I have sent you an email through which we can continue further. I'll trace the schematic and send you in coming days. Check your mail...Cheers
Re: password for technology.zip file
ge_narayanan said:
hi shiddu.b
please send me the password the technology.zip file to my mail id
thaks
narayanan.e
There is nothing to share in private through the mail id. The reply to your querry is already been given before. Go through the previous posts in the same thread.
sudipmuk said:
sahu said:
dear sudipmuk plz send the password for technology.zip
Dear venkey3777 & sahu...Sorry for the late reply . But i donot have the password for that file technology.zip. And one more thing , saleem.shek has written a great thing. No one is going to give u a commercial design for free.
hi friends here is the link for obove mentioned card
This info was helpful for me. But as this thead is not mine, i coudnt press "Helped Me" For you. For that, i have donated 20 points. Cheers
I will soon post here a schematic for the pic16f72 based quasi sine wave inverter
using bta 16 scr based charger. for 800va & 1250va.
There are very few chances that some one will have a readymade code for your schematic. Even if he/ she posseses, it may have bought from some technology vendors which is hardly shared. BTW there are quite a lot members waiting for a complete 16F72 based inveter with codes and PCB. But no one has shared a complete working project / technology till date. If you have the same, you are most welcome to share it.
Cheers
jayananda said:
hi friends...
pic 16f72 based sinewave inverter is working. but there is sum modifications required. i.e the relay driving transistor polarity and connections.
and one more thing is in given asm file having only single step charger, switching freq is 5.6khz, that is not suitable for long life. if any body having multi step charger with 16khz switching frequency. please post here and im having many typy pcb layouts. i will post those here.
Hi jayananda,
please give me the ASM file & HEX file on which your inverter is working, and also tell me the compiler name which you are using. The ASM code which i have found from a forum is not properly documented and also not working after compilation.
Thanks & regards
Jags
hi friend i will post here hex code and circuit modification details. please wait ......
HI
NOW BODY HAS POST A COMPLETE SOLUTION SO FAR AND THE SUMMER IS SHINNING.
MOD: Do not use upper case letters unless required or mandatory. You are warned.
who can explain the 72 sine.asm briefly?
Nice...asking lessons in the first post. Upload your Source code (ASM) and then expect some one to explain it. :D:D:D:arrow::arrow:
I am the designer of this card and I can help people to develop more cards on PIC>.
Thanks
hari
Thanks
hari
hello harimelath. if you are designer of this card, than post your source code here.
all are developing with your support.
Source code cannot be shared on public forum, Its a development made spending several months and extensive field trials.
Hi harimelath,
I am interested in knowing the method you used to develop the SPWM and charging circuit using the PIC16F72 and the features, ie battery low-cut at what voltage, overload sensing, battery charging, line voltage sensing (if done), charging current control, etc.
Hope you can share at least this if not the source code. Actually I've developed a quasi-sine inverter with ATMEGA16/32. I want to see how you have implemented a sine wave inverter on the 16F72.
Re: free source code for sinewave inverter
Please Tahmid, i can not access the ASM code for pic16f72 sine ups
Pls Tahmid, how do i access the ASM code for 16f79
Hello tahmid
I hve a lot of diagrams which can meet yors mentioned question/requirements. plz tell whether you want diagram or explanation in writing.also let me know how the the diagram is uploaded here ,because I am beginner in forum and don't know the way,you helped me a lot previously.Regards
Hello tahmid
Most welcome to share your circuits and codes. Despite this thread is 5 pages long, till date no one has shared a complete Inverter project with 16F72. For uploading, you may click on "Manage attachments" and attach your files. You'll get a link which you may then copy >paste it in the text box and "submit"
Cheers
