pnjbtr
Full Member level 5
Its not a problem,these pins should low during charging.The main problem which I have to face is that,the OSC3,OSC4 become LOW condition containing 0 volts during Charging
If you need, we can make high these pins.
These pins are high for a while,till chg led start blinking.while the OSC1,OSC2 remain in working condition containing 1.5 volts each.
When charging occurs,these pins start switching.
You should keep sight on pin 5 of mcu.
This pin is controlled with chg control trim pot.
Here 3.25 volts are for stable charging.
If volts at pin 5 are below then 3.25, mcu will change, and increase on time in pwm pulses.
Thus charging current also become high,volts at pin 5 also vary with charging current.
In level 56 you can change these volts.
