ALERTLINKS
There is self discharge of battery which is diffent with individual battery. This is all to keep up with this This can only be estimated by battery voltage. Simbplest is maintaing charge between two levels charger either switched by relay or transistor.Like automatic pump maintains between upper lower and lower level It is good for first stage only.
On the other hand there are ics specially made which manage all three recomended stages for battery charging. bq2031 is a popular ic
https://focus.ti.com/lit/ds/symlink/bq2031.pdf
It can also implemented in mcu.
If you want complicate things a watthour meter can be constucted for battery discharge using mcu and then charging
in accordance taking care of losses.
