bigdogguru
Administrator
- Joined
- Mar 12, 2010
- Messages
- 9,821
- Helped
- 2,350
- Reputation
- 4,694
- Reaction score
- 2,272
- Trophy points
- 1,413
- Location
- Southwest, USA
- Activity points
- 62,395
Hi all i found a zero crossing optocoupler.
This is what in my mind and i want to ask you guys if it will work this way.
since we are using zero crossing optocoupler does it mean we dont need anymore to use a zero detection circuit?
You need a separate zero-crossing point trigger input for the PIC, so the PIC can effectively control the TRIAC. Otherwise the PIC has no idea when the zero-crossing point occurs.
Unless you want to use the technique FvM suggested, unsynchronized PWM control.
FvM:
It uses a zero-crossing-detector triac. As I previously explained, you can use it with slow pwm control (e.g. 1 to 4 secs period) without synchronization to the AC voltage.
BigDog
---------- Post added at 16:02 ---------- Previous post was at 15:44 ----------
Here's a datasheet of a similar device:
OPTOCOUPLER TRIAC-OUT ZERO-CROSSING 6-DIP
The datasheet has some example applications towards the end of the document.
