@t
Member level 3
- Joined
- May 14, 2005
- Messages
- 66
- Helped
- 5
- Reputation
- 10
- Reaction score
- 4
- Trophy points
- 1,288
- Activity points
- 1,724
Hoi Pierre, you said:doc007 said:- I have taked out U1 U2 U3 and U4 ( R41 to R48 unsolderd on the side of TLP)
- Q1 and Q5 lamps between (B and +U ) and ( B and gnd )
=Can I test with +10V on R41 and than on R45 to see they switch ?
If it is OK I will make the test with Q3 and Q7 lamps between (A and +U ) and ( A and gnd ) ...
It seems to you correct ?
Pierre
- taken out U1,2,3 and 4, but you do mean: U3,4,5 and 6, right?
- Lamps in series between gnd and +U, and the midpoint connected to B, is ok.
=Yes, test with pos. voltage and a serie resistor on the Fet gates (R41 and R43) will switch the upper (Q1 lamp) off, then on R45 and R47, that should switch the lower (Q5 lamp) off. You might connect a 10k resistor from gate to source (or R41 to B), so that the Fet gate is not floating during test.
Warning: Do not switch Q1 and Q5 Fet on at the same time, because one of them will leave this Earth then. A temporary series resistor (1 or 2 ohm) or fuse in the +U line will prevent that.
Good luck, At.
