[SOLVED] Pic 16f876a Pure Sinewave inverter
Hi doc007,
Does it works inverter when signals a and b are linked to the MCU input pin.
And how you measure these two voltages (a and b), with meter or with oscilloscope.
You should check it with scope only. They are AC signals with low frequency (50Hz) and if you masure it with meter, then you measure their average values.
Best regards,
Taner
Hello Taner
I have mesured these two voltages with a meter.
The inverter does not work when signals a and b are linked to the MCU input pin.
I will check these two voltages tomorrow with a scope .
Pierre
Helo Taner
With the scope, I have no signal a or b on pin 1 and 2 of U10.
Perhaps it 's normal because the inverter does not work.
In effect In main programù if ( high_ab ) PWM duty =0
I am going to reverse a and b on pins 1 and 2 of U10
Pierre
Hello
After reverse a and b on pins 1 and 2 of U10 I have the same voltage as before the modification. (4.64 V )
I must specify that the mesured voltage are DC voltage .There is no AC voltage --> no signal on the scope and inverter is not working. ( leds out )
What can be the problem ?
Pierre
Re:cam output Sinewave inverter
hello seki
what are ic1-4-5 in cam output.pdf ?
is it opamp same lm358 or what.?
thank you
good idea.
gatabil said:
hello seki
thank you
good idea.
HELLO gatabil
I used a LF412
But I think a good 4558
The pattern was designed using PCBE2
Note that some me just does not matter
Hello friends
Has somebody an idee to help me to resolve my problem?
Thank you for the answer
Pierre
Added after 51 minutes:
Hello Taner
I have proved my circuit and everything seems correct: contact and soldering .
The only difference with the schema is the absence
on my circuit of the 2 capas C41 et C42 through lack of place .
could it explain the non functioning of the circuit ( not enough energy ??)
pierre
Hello Taner
I still search the reason of my problem.
I take away the mcu and the 74HC257 . Therefore there is no more command of the output stage.
however I have 4.58 V DC on a and 4.57 V DC on b.
Is it normal ?
The IRL 3803 are passing without command ?
I have mesured the different Vgs :
0.476 V Q3 et Q4
0.485V
Added after 4 minutes:
Hello Taner
Is it normal ?
0.476 V Q3 et Q4
0.485 V Q1 Q2
0.020 V Q7 Q8 Q5 Q6
It seems to be under the Threshold voltage
What do you think ? am I wrong ?
Excuse me for my questions ?
Thank you
Pierre
Hello Taner,
If I have good understand I must remove in MAIN
While
the condition IF (or high_ab)
Pierre
Hello Pierre,
I removed the a/b voltage check from software.
Please find the attached archive file included .c and .hex files.
Best regards,
Taner
Reactions: zuberi
    zuberi
Hello Taner
Thank you
I will test it tomorrow
Pierre
Added after 27 minutes:
Hello Taner
I am too impatient and I have made a quick test without feedback and load. ..........
THE INVERTER SEEMS TO WORK !!!!!
Orange Blinking during 5 sec and after Green Blinking...
Tmorrow i will check the inverter with all the feedback and load.
Thank you very much.
Pierre
PS Can you say to me why the a/b voltage check prevent the functioning of the inverter ?
doc007 said:
PS
I'm writing your program in assembleur MPLAB of Microchip
If Somebody is interested ?
Yes doc007, I am interested in the asm code, I can wait until the current (ab test) is solved ofcourse.
Greetings, At.
Hello Pierre
Starting of the inverter with heavy loads leads to flowing of high current through MOSFETs and high a/b voltage level.
After starting of inverter, is there a normal levels of a/b voltages?.
Best regards,
Taner
Reactions: zuberi
    zuberi
Hello Taner
For the tests i use a trafo toroidal :6V/220V and no feedback on inverter.
1) Without load no problem : blinking orange 5 s. then blinking green.
During standby I have a click in the trafo with the same frequenz as the blinking.
When load opération ( lamp 40W) trafo make a big noise and became rapidely warm.
The primary has 11 V and the secondary 280V !!!! but the sine wane is not a real sine wave .the top and the bottom of the sinusoide is flat : Saturation ?
The a:b on the pin 2 from MCU is 2.1 V
Thanks
Pierre
Hello Taner,
I have found a trafo 16V/220V and the noise of the trafo has disappeared .
consequently the tension of exit has fall of 130 V .
But my sine wave is only a square wave
The a and b signals on pin1 and pin2 are 2.3V and on pin 2 of MCU I find 30 mV.
Pierre
OBIALOR said:
HELLO SEKKI, HOW CAN SOME ONE GET YOUR SO CALLED PCBE2.?
HELLO
Can be downloaded here
Am I just the Japanese version
THANK YOU
sekki said:
HELLO
THANK YOU
Hello Sekki, that site is pure Jappanese, can you present us with some form of information that we can understand? A schematic, or some translation?
Greetings.
