Materials bought on Ebay are a good for low cost PCBs, at least if you don't expect the same 8/8 resolution that is achievable with presensitized boards.Otherwise there are ebay yellow or white papers you can buy them on www.ebay.com
The easiest way is to buy presensitized boards (like those manufactured by Bungard and others), there are tons of resellers on Ebay and AliExpress so anyone can buy them. They ship worldwide.
I make boards using the process described in this article: https://www.ijeir.org/administrator...arch/files/publications/IJEIR-454 Final N.pdf
Exposing presensitized boards under UV, developing in sodium hydroxide and etching in iron perchloride.
Hi, Mvs sarma
I have been looking in this negative sensitized photo resist film on aliexpress.
Where do you get this film in India?
Can you explain the whole process of this method ?
They laser print two copies on transparency, then couple them together to get darker black.thanks for the video...
How much time did it take to deliver here (if you did the free shipping)?
In that video, How did he get the printed circuit on the film after laminating it. Was it a different film which he printed at the start ?
Manufacturing PCBs is unfortunately not cheap. I can recommend you to check out your local fabab for assistance. Many fablabs have equipment for PCB prototyping (including etch tanks, exposure unit etc) and they buy the required materials in far larger quanties at cheaper prices. If you're a student or below 18, many fablabs also give you a discount.They are costlier. but for lucky few, many can't afford .
the process is equally cumbersome.
hi mvs sarma,
https://youtu.be/cRCFGZxmob0?t=4m24s
this video starts from where my confusion starts
I don't understand how did he get the toner part on the film (where the video starts)
Is it something like (in the order of sandwich)
[glass-pcb(copper clad)- photoresist film- (any printed film)-glass] ?
I hope this doubt is clearer ?
And how much time did it take to reach at your place from Aliexpress. I have order one and waiting ;-)
A4 Sheets Heat Toner Transfer Paper For DIY PCB Electronic Prototype MakThanks for all. I seen that the yellow colour art sheet is showing better performance than white one. I able to do minimum of 0.2mm. Track to track space 0.2mm. I am interested about the name of the sheet.
