Need Help doing C Language Programming for PIC18F4520 MPLAB lCD 3
Try this program
HTML:
#include "18F4520.h"
#include <delays.h>
#pragma config OSC=LP
#define _XTAL_FREQ 32768
#include "lcd_1.c"
#define E LATDbits.LATD6
#define R_W LATDbits.LATD5
#define RS LATDbits.LATD4
#define LCDdata PORTB
void main()
lcd_init();
delay_ms(100);
while(1)
R_W = 0;
lcd_gotoxy(1,1);
delay_ms(1000);
lcd_putc("\fREADY...\n");
use this driver
lcd_1.c
HTML:
//// LCDD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// (C) Copyright 1996,2007 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
// As defined in the following structure the pin connection is as follows:
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
// LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
 #define use_portb_lcd TRUE
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#if defined use_portb_lcd
#locate lcd = getenv("sfr:PORTB") // This puts the entire structure over the port
#ifdef __pch__
#locate lcd = 0xf81
#else
#locate lcd = 6
#endif
#define set_tris_lcd(x) set_tris_b(x)
#else
//#locate lcd = getenv("sfr:PORTD") // This puts the entire structure over the port
#ifdef __pch__
#locate lcd = 0xf83
#else
#locate lcd = 8
#endif
#define set_tris_lcd(x) set_tris_d(x)
#endif
#ifndef lcd_type
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#endif
#define lcd_line_two 0x40 // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
BYTE low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
if(y!=1)
address=lcd_line_two;
else
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
break;
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
this is the new error for it
//// LCDD.C ////
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
struct lcd_pin_map // This structure is overlayed
} lcd;
#locate lcd = getenv("sfr:pORTB") // This puts the entire structure over the port
#ifdef __pch__
#locate lcd = 0xf81
#else
#locate lcd = 6
#endif
#else
//#locate lcd = getenv("sfr:pORTD") // This puts the entire structure over the port
#ifdef __pch__
#locate lcd = 0xf83
#else
#locate lcd = 8
#endif
#endif
#ifndef lcd_type
#endif
// to start it up.
BYTE low,high;
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
lcd.rs = 0;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING);
BYTE address;
if(y!=1)
else
address=0;
address+=x-1;
switch (c) {
delay_ms(2);
break;
char value;
lcd_gotoxy(x,y);
lcd.rs=1;
lcd.rs=0;
return(value);
#include "p18F4520.h"
#include <delays.h>
#include "lcd_1.c"
void main()
lcd_init();
delay_ms(100);
while(1)
R_W = 0;
lcd_gotoxy(1,1);
delay_ms(1000);
here is my code
lcd_putc() functions prints one character on lcd. It doesn't print strings.
See if this code prints character A on lcd.
#include <delays.h>
#include "lcd_1.c"
void main()
lcd_init();
delay_ms(100);
while(1)
R_W = 0;
lcd_gotoxy(1,1);
delay_ms(1000);
lcd_putc('A');
Your crystal frequency is 4MHz, not 32.768kHz.
Try programming your board using the hex file in the attached project.
If it works, then try compiling the C18 project.
For full benefit, connect serial port to a terminal at 9600,8,n,1 no handshake. Option "h" reads the on-board temperature sensor.
  • mon18.rar
Hi inneed of help,
Once again i'm confirming it,
RS pin to PIN D6
EN pin to PIN D4
R_W pin to PIN D5
data pins to PORT B
Unzip the file and import the hex to your mplab and program it. It should work. I checked it in my case. I'm displaying a string "Electronics" by sending one by one character.
Also please explain how you are importing and programming the file to your microcontroller. Please try it ..
  • main.rar
only need to import the hex file to my Mplab ide will do ?
yes 8 bit.
