Looking for schematic for ICD2
Re: Schematics for ICD2
to ninjia:
first, did u read the rules and regulation? did u do the searching?
2nd, the main reason to replace CY7C64603 with 4550 is because CY7C64603 is no longer being produce. MICROCHIP is substituting it with 4550 where it is programmed to work exactly like the cypress chip. and wats even better is that MICROCHIP is producing the cheap themselves. save production cost and utilizesown product.
3rd, all needs hex or firmware. CY7C64603 uses some firmware which is stored in an external EEPROM. else MPLAB would not recognize what it is and there wouldn't be any communication.
hope that can clear u on ur doubts :) feel free to ask.
to samir mistry:
search first k? tusb3410 actually converts data from usb to rs232. what differs here is actually the overall speed. it is not much different more than using a serial port. just a converter in the middle. 877a still have to wait to collect the 8 bits form the serial converter. as for the cypress o 4550, it converts the data straight to parallel so 877a can process the data directly. all bit reaches at the same time without having to convert it from serial to parallel again. u kno the the math :)
ps: SORRY if sounded to harsh everyone. (TO ninjia AND samir mistry as well.)
Schematics for ICD2
sorry for stupid question. Do we really need the 74hctxxx? Can the clone work fine without them?
thank you.
Hi Everyone
Have anyone tried to build the ICD2 using any USB enabled pic microcontroller?
fouad_jh said:
Hi Everyone
Have you read the topic list under microcontrollers?
this is ICD2 schematic i found in sixca.com
I've go to this website but unable to get the PCB board and hex file for PIC12F508A. I tried download the attached file, but failed to open...
Anybody have the copy of this zip file?
Added after 10 minutes:
Ok...i got it...i tried download for second time and able to open thsi file...thank you...
Anybody have experienced with this circuit?
cristiandinca said:
Is there someone who has the schemtaic for ICD 2 ?
Hi all.
Look at thisone
Hello blueroomelectronics,
I have built your design, and it works like charm!! :D Congratulation for the plans!
Thank you very-very much!!
adlertag
adlertag
You're welcome :D thanks for the feedback.
Hi all!
This is the real original ICD2 MICROCHIP schematic!
http://home.tiscali.cz:8080/tomeco/files/ICD2original.PDF
Good luck!
hi...
icd2 PCB pdf format and 877A-bootloder
Source Link:
www.blueroomelectronics.com
for 877 hex mplab-BL010101HEX...
Thanks a lot!
Schematics for ICD2
thanks a lot, finally a simple and well tested ICD2!
funnynypd said:
Well. Cannot see the new desig.
It's on my site, Unicorn is an 18F4550 upgrade to the new Inchworm+
Schematics for Unicorn are offline, but will be posted asap.
can be BS250 d-MOS changed by other transistor, like a BC337 p.e.?
Thank you..
Hi blueroom
A little bit off-topic, but how do you do these beautiful board 3D drawings?
Is it very hard, or automatic?
Rec
blueroomelectronics said:
The drawings are created with Sketchup 3D and my own libraries.
Hum, I downloaded and tried Sketchup for a few minutes. Not so easy, me thinks.
I would say you are a true Sketchup pro by now!
The drawings look better then the picture of the real thing :D
