Looking for a PIC program for battery voltage indicator cum cut off circuit.....
Try this code. You have to make TRISA = 0b00000011;
Which version of micro c you are using?
I try with version 5.30 and build,but no effect of adc on lcd.
  • 3rd.rar
I am using mikroC Pro 5.60
The problem was with your Clock frequency settings in Proteus and ADCON1 settings. You has chosen to use Vref+ and Vref-
If you want your code to work. Connect vref+ pin to 5v and Vref- pin to Ground and try, or you can use my code. I have not used Vref pins.
Try to see the errors and warning messages proteus give.
  • 3rd.rar
Reactions: pnjbtr
    pnjbtr
What do think problem is due to version mismatch?
i attached whole project in previous thread.
Can you build c file and send hex.
can we write this code for pic16f72?
PIC16F72 have 8 bit adc module and pic16f877a is with 10bit adc module.
