longcrystal
Junior Member level 2
I did simulate it with different values already.
I am not angry. I am just trying to teach one simple thing:
An LCR low pass filter is only called a "Butterworth" filter if the response is -3dB at the corner frequency. Any other LCR low pass filter is not a Butterworth filter.
Agreed. A damped filter, as you showed in post 34 is one way to deal with it. The alternative, as pointed out by Goldsmith, is to use feedback to control the response.
The current drawn by a load like that will have high levels of harmonics at frequencies well above 50Hz, so it is important for the inverter to have a low output impedance even at those frequencies. I guess that's one good reason to make the inductor smaller rather than larger in value.
hi thank for godfrey and goldsmith discussion .. i am sorry about that ... i dontknow a lot thing for the filter something... i need to study more..then will be come back and ask ~~~~~now just wondering....for the inverter design... if i predict the delay on and delay off ..to generate the pulse as i show in below
Uploaded with ImageShack.us
the off pulse i setting 0.2ms and On pulse i setting various of period 0.5ms ,1,0ms ,1.5ms , 2.4ms
then make the spwm pulse full cycle in 50HZ range........but i have asked my lecturer...my lecturer ask me back...what is ur spwm pulse frequency i said 50Hz...he said ...i am wrong...i can sense that i am wrong ..understanding...but for my own concept...
i am trying to predict ( 0.2ms X No.off pulse) + ( 0.5ms + xxxx+xxxx) =20ms
so F=1/t = 1/20ms = 50Hz <----for spwm range as the picture show.......
but the main problem is coming for my concept maybe totally is wrong.....because i refer from other website....they used triangle wave and sine wave ....combine together ....and measure the intersection for sine wave with the triangle wave.....so for my own understanding triangle wave = carrier frequency ......
sine wave = modulation frequency and the spwm is depend on the intersection for this both frequency only can draw it out.........for my case....i predict spwm 1st....but i didnt know ....how many carrier frequency for my spwm...i just can answer that i use off pulse 0.2ms and 0.5 1.0 1.5 2.4 ms do the 50 Hz pulse....but i want to understand that .....who can explain for me ...how to i find carrier frequency for the spwm.....because this is the purpose for i further data value for design filter...without this ..maybe very hard to continue ..to design LC
So i read this website for small understanding a bit ..but i am still confused...http://www.imakenews.com/eletra/mod...09&show=F,T,T,T,F,Article,F,F,F,F,T,T,F,F,T,T
so in my case i predict spwm 1st....but for the real theory in inverter..must produce triangle and sine wave 1st..only can do next step for the spwm pulse...but in my case i jump the step....because i dontknow how to generate the triangle wave in H-bridge application...and i saw some where for the concept of inverter .they used bubba oscillator to generate triangle wave..but i hope i dontwant to use this method to build out my inverter..because it look like not necessary to use this way ....So.....hope anyone can help with this ...explain simple and reasonable concept to me .......and for my case ...after spwm is LC filter i had read this low pass filter concept for cut the high frequency of my carrier into low frequency http://www.corollarytheorems.com/Design/filter.htm
and last time post the comment..godfrey is reply for me cut off frequency is higher than the 50Hz...i didnt get this meaning.. Cut off frequency should be much higher than 50Hz. If the PWM frequency is 5KHz, then the cut off frequency could be about 500Hz..i dontknow why cut in 500Hz...as i expected the output is 50Hz...why i need cut at 500Hz..but i am know u are right...maybe i didnt understand about that..hope u can explain to me simple way........
thank for help and regard
