JDM Programmer Advance Hardware
pls which software works on pc with this hardware
please never asked useless question,which software to work with hardware already describe in very first post of this topic any how i can told you again
1) winpic800 (highly recommended)
2) winpic (recommended)
3) ICprog (works but performance is compromised)
hope this will clear every thing
Fragrance
Respected Fragrance Sir
I have tried your circuit and the device is not able to detect by software i have built the circuit in breadboard and all the connections are correctly connected. when i click check Hardware in winpic800 it says "Unknown Device"
I have measured the voltages on all the ic and transistors and it gives me the following Values
BC547
Collector=11.54v
Base=-8.25v
Emitter=0(as it is connected to gnd)
BC557
Collector=2.42v
Base=11.6v
Emitter=12.32v
CD4093
Pin No Voltage
1 -0.68v
2 -0.68v
3 4.98v
7 0(connected to gnd)
8 4.98
9 4.98
10 -0.05
11 4.98
12 -0.68
13 -0.68
14 4.98
IC MAX232
Pin No Voltage
1 -1.14
2 -.77
3 -2.26
4 -1.66
5 -3.29
6 -4.38
7 -1.78
8 -9.68
9 -.68
10 -.05
11 0(GND)
12 -.68
13 -9.65
ic 7805
Input 12.35v
output 5v(approx)
ic 7812
input 1.35v
output 12.35v
Please take a look and tell me where am i doing wrong
am waiting for your reply
Thanks in advance
BC547
Collector=11.54v
Base=-8.25v
BC557
Collector=2.42v
Base=11.6v
Emitter=12.32v
CD4093
Pin No Voltage
1 -0.68v
2 -0.68v
3 4.98v
8 4.98
9 4.98
10 -0.05
11 4.98
12 -0.68
13 -0.68
14 4.98
IC MAX232
Pin No Voltage
1 -1.14
2 -.77
3 -2.26
4 -1.66
5 -3.29
6 -4.38
7 -1.78
8 -9.68
9 -.68
10 -.05
11 0(GND)
12 -.68
13 -9.65
ic 7805
Input 12.35v
output 5v(approx)
ic 7812
input 1.35v
output 12.35v
Thanks in advance
it is better to make a PCB rather then breadboard
Fragrance do you have a list of PIC's which this programmer supports?
i am also using one such jdm programmer.. there is one problem, it is programming only brand new PICs, but when i tried to reprogram verification errors occurred every time.. do u any idea about its solution? Thank u!
Hey guys... any new uldate about this usefull jdm programer i used to do it but it didnt works well... winpic didnt detect it so when i try's to program the pic using picpgm the data LED bright then off any help or update?? Thank you
